My screen has turned 90 degrees counter clockwise,i am still able to use the computer but everything is turned,how am i able to fix this condition?
    Problem Solver:
  • 5 Answers
Some video cards have detailed settings available, to include doing what you describe so the monitor (specially built ones) can be turned on it's mount, mostly in order to display a tall legal-sized document full-screen. Pretty cool, if you're a lawyer or something, but not if you didn't plan on it happening! Get into your video settings in Control Panel and go through it carefully to see if a box got checked by mistake.
Posted on Nov 10, 2008
How to fix a signal light in a shadow spirit motorcycle
pull the glass cover off, pull the bulb out, push replacement into place. NOTE: you might have to twist the bulb 90 degrees to get it out (counter clockwise).
Aug 28, 2014 | Honda VT 750 DC Shadow Spirit Motorcycles
My computer just went belly up! It is a reconditioned IBM ThinkCenter, a little over 2 years old. It was running normally and then all hell broke lose, cooling fan went berserk sounding like a hair dryer...
you need to clean the heatsink of the processor remove it from the motherboard by turning the lock to counter clockwise to 90 degree only all four lock then pull it up gently check for the thermal paste if it is dry you need to add a new thermal paste before you add make sure that you clean the back of the processor or remove the old paste that already dried out, just a small amount you need to apply, then before placing back the heatsink to the processor make sure you already turn the lock to lock position by turning it clockwise 90 degree then make insert it correctly to the four holes in the motherboard then press the lock down slowly to lock one by one,
Aug 04, 2011 | IBM Computers & Internet
How do you change out water filter?
Hi and welcome to FixYa, I am Kelly
Press in hard.. rotate it 90 degrees Counter clockwise and wiggle / pull it out. When you re-install a new filter align the filter with the internal locking tabs and press in hard and rotate 90 degrees clockwise.
Some times the filter can br really fussy to remove you just have to keep wiggling and pulling to get it out of the recepticle once you have rotated it 90 Deg CCW.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
All the item in my screen are rotate 90 degree counter clockwise ( horizontal ) how to change it to vertical position?
hi
press these keys together
ALT, CTRL and use the arrows beside up-down-right-left , to correct the view.
Feb 14, 2011 | Computers & Internet
Where is the water filter located?
The filter is in the refrigerator section in the space behind the vegetable bin. Thus pull the bin out to change your filter. Then remove the cap by rotating it counter-clockwise. Remove the old filter (turn 90 degrees counter-clockwise and then pull out) and then take the protective cap off your new filter. Slide the new filter into the housing and then rotate clockwise 90 degrees. The alignment marks should indicate the filter is locked into place. Then replace the cap. Remember to run water through the dispenser for several minutes to clear the lines.
I hope this helps.
(I don't have a manual for the RS2630WW; however, the Samsung RS2630SW should have the filter in the same place.)
Oct 23, 2010 | Samsung RS2630WW Side by Side Refrigerator
Pic up side down
  • Open the picture(With Windows Picture & Fax viewer)
  • Type "CTRL+K" to turn the picture 90 degrees clockwise. Additionally, instead of using the command keys, you may select the "mountain" icon. This icon located next to the magnifying glass icon on the bottom of the picture.
  • Type "CTRL+L" to turn the picture 90 degrees counter-clockwise or select the second mountain icon. This icon located next to the red "X" icon on the bottom of the picture.
  • Repeat the steps, changing the number of degrees as needed to adjust the picture to the correct angle.
  • hope this will help you... Have a Nice Day
    Sep 25, 2010 | Computers & Internet
    My monior screen is flipped 90 degrees counter clockwise
    Press the CTRL key, and ALT key down at the same time. Now tap the Up Arrow key.
    Oct 06, 2009 | Acer Aspire 5100 Notebook
    I pushed some keyboard sequence by accident and my screen turned 90 degrees counter-clockwise. How do I undo this?
    To undo this, press "CTRL + ALT + Up" arrow keys together.
    Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
    Aug 27, 2009 | Televison & Video
    Screen has turned 90 degrees counter clockwise
    press ctrl alt and the up arrow button at the same time and it should work fine
    Jun 06, 2009 | Dell Inspiron E1705 Notebook
    Computers & Internet Logo
    35 people viewed this question
    David Payne
    David Payne
