Question about Refrigerators
Frigidaire frs26zrf My fridge part won't cool. Electric to both sides fine and freezer works good. Fridge side not cool at all but warm. model frto4lg3db. The freezer part works but the refrigerator does not cool. the freezer is on top and this is a small compact refrigerator capacity is 3.8 cu. ft.
  • 2 more comments
  • Tucky1971 Nov 09, 2008
    Yeah I have the same problems. Side by side Frigidaire FRS26ZSH. Freezer is fine, but refridgerator isn't working. Any suggestions? Should I call a repair man? Thanks for any help.
  • pahpahd69 Nov 10, 2008
    The evaporator fan is working. What next?
  • mrh4772 May 04, 2009
    FRS26ZRF Frigidair side by side, I to have the same problem. 2 years ago a repair man reccomended we unplug the unit and clean the coils under the unit as well as possible. After an hour of being unplugged we plugged it back in and it worked. now we are having the same problem of the fridge side not getting any cold air but the freezer works fine. What would be reccomended besides paying someone to fixe it at almost the same cost of a ne unit???
  • Anonymous Mar 22, 2014
    frigidaire compact refrigerator won't cool
  • 120 Answers
Posted on Nov 10, 2008
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
Frigidaire Refrigerator is warm on top of the frig and freezer but fine on bottom.
Remove the rear lower panel on the unit check to see if the compressor is hot or if its running, should feel the vibration, also listen for any clicking noises.
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Frigidaire frs26lh5dso freezer works great, fridge side is warm.
make sure door to refrigerator is all the way up, so when it is closed it turns the cooling part on. I have to check mine all the time and screw it up if it's down, which is quite often. Mine is a side by side and I just make sure it's even with the top of refrigerator and even with the freezer door.
Jul 16, 2012 | Frigidaire Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Frigidair Gallery fridge/freezer... Freezer is
change the control board in the rear lower left corner of unit part# 4334000 2 appliance parts pros
Oct 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
Jan 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
Mar 30, 2008 | Frigidaire FRS26ZSG
Frigidaire Fridge PLHS69EESS2
Could be a jammed fan or something could have moved inside to block the opening. Some units have deflectors in the openings...did one of those cover the opening on the fridge side? Did you overpack your freezer and block the air flow from there to the fridge?
Dec 29, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
1,070 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
