Question about Canon BJC S800 InkJet Printer
It is stuck!!
I was performing a routine cleaning when it suddenly stoped followed by a "grinding" noise, almost like a car's start engine. The indicator light is blinking 4 oranges between 2 long green ones (replace empty ink), but the cart doesn't move to the center, neither make a noise. Every time it is powered on it makes the noise. I try to reset: 1) Power off printer 2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.) 3) Hold POWER and Release RESUME. 4) Press RESUME twice then release both POWER and RESUME buttons. 5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently). 6) Press power to set data. It still refuse to move. Is there hope for it? It has been the best printer we ever owned.
  • Staria_13 May 31, 2008
    Same here!!
    Any solutions yet?
    Top Expert:
  • Canon Master
  • 25,352 Answers
When changing the hdd it must be paired with the DVD player using the Service Remote Controller to be found only at Authorised Pioneer Service Centres.
Posted on Mar 17, 2017
4 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Waste Tank Counter Reset - Canon i550
Hi
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
  • 381 Answers
SOURCE: I had a paper jam Problem with the PIXMA? iP6009D
there might be some paper stuck in the rollers or which is blocking the sensor hence the msg. just give it a good check
Posted on Oct 15, 2010
  • 544 Answers
SOURCE: can't align head - used those instructions: 1)
The following web page from canon support will help you do an alignment.
Click on the bottom of the solution list to pick your alignment options.
Click - Back to Ressult - upper right corner to get back to the solution list
you can then reselect a different option.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#ServiceAndSupport
Posted on Dec 27, 2010
I have a 2000 ford f350 7.3 i was driving home and all the sudden i herd a loud grinding noise and then something broke and klanged and banged for a sec then stoped know i have a random grinding sound whie...
check for broken suspension components. Shouldn't be hard to find the culprit, if it is grinding it is making metal shavings and should be able to look for shiney metal parts.
Aug 04, 2014 | 2000 Ford F350 Super Duty Super Cab
Loud grinding noise within the engine and stalling after braking hard
Flex plate is cracked. That is another reason it stalls.
Nov 08, 2011 | 1996 Eagle Vision
Lens makes grinding noise
yes dust in mechanism or broken gear but ti not easy
Oct 12, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
HP 1720 I making a noise when printing.
    NOTE: Refer to the Testing section in this document for instructions on performing the tests.
  1. Turn the printer off, and then turn the printer on. The grinding or squeaking noise should not occur while the printer is initializing.
  2. Perform a paper path test. The grinding or squeaking noise should not occur because the carriage should not be moving.
  3. Perform a self-test to localize the noise.
  4. Check the printer for obstructions by lifting the top cover and making sure nothing is blocking the carriage movement.
  5. Check the paper path by following the instructions below:
    1. Remove all media from Trays 1, 2, and 3.
    2. Pull out any visible stuck paper.
    3. Lift the top cover, and pull out any jammed paper.
    4. If you are unable to free the jammed paper, pull out the handle of the paper knob, pull the knob away from the printer, and rotate it to remove the paper.
    5. Lower the rear access door by lifting up on the two rear door latches.
    6. Remove the back panel by pushing the two catches inward.
    7. Pull out any paper that may be stuck inside.
  6. Wipe down the milky white strip (see Figure 1) that the front of the carriage glides on with a clean, soft, dry, lint-free cloth.
Figure 1: Location of the white strip
bpp90119-1.gif Replace the whole unitgtabtop.gifIf the printer is still making a grinding or squeaking noise after following the steps above, replace the whole unit. See Whole Unit Replacement instructions, which are included with the whole unit replacement.
Testinggtabtop.gifUpon replacement of the whole unit, perform a Paper Path test and a self-test as described below to verify that the new unit is functional.
    Performing a paper path test
    1. Press the MENU button on the printer control panel until Diagnostics Menu is selected.
    2. Press ITEM until Perform Tray x Paper Path Test is selected.
    3. Press SELECT to perform the test.
    NOTE: The paper path test will terminate only when the paper in the tray being tested runs out or the printer is turned off.
    Performing the stand-alone self-test
    1. Press the MENU button on the printer control panel until Self Test Menu is selected.
    2. Press ITEM until Print Menu Map is selected.
    3. Press SELECT to perform the stand-alone self-test.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | Dell 1720dn Laser Printer
Grind Off lamp blinks continuously.
An extended power off period remedied the situation.
Mar 19, 2009 | Cuisinart DGB-600 Coffee Maker
Renault clio over heated stoped dead/head gaskit
is the oil/water a milky colour? if so, then yes, your head gasket has blown
Feb 16, 2009 | 2000 Renault 181
Grinding noise
In my humble opinion, a dryer making a grinding noise is worth repairing. Possible Problems:
Worn Drum Rollers (Very Likely): More of a thumping / grinding sound. Replacing drum roller supports is considered to be a routine "normal ware & tear" repair with parts costing about $15 - $20 or so. Its' kinda like a tune-up for a vehicle. The rollers can be located in a couple places, but are typically located on the inside rear of the drum; upon dis-assembling the dryer.
Broken/Loose Blower Fan Wheel (Likely): The blower wheel can become loose or brake off the motor shaft and can make a "rumbling / grinding sound and can run about $15 - $25 for the part. The degree is difficulty when repairing a little high, but is commonly performed.
* Note: Removing and threading the blower wheel is reverse to prevent the fan blower from natually spinning/coming-off "Righty loosey, lefty tighty"
- C
Jan 27, 2009 | Maytag Dryers
We were driving in 4 wheel drive in a snowstorm and all of a
Sounds like the rf hub and bearing assy has had an internal failure. Take it to a local shop and they should be able to confirm.
Jan 14, 2009 | 2000 Kia Sportage
OKI C5100 Making grinding noises
Click the following link, it should solve your problem
http://www.fixya.com/support/t238726-sensor_error
Regards Wayne
Aug 05, 2008 | OKI C5100n Laser Printer
Canon BJC S800 InkJet Printer Logo
53 people viewed this question
old marine
old marine
