Question about HP Pavilion dv2000t Notebook
Will not start in windows
Power but no view
  • Uwe Klopfer
    Uwe Klopfer May 11, 2010
    are the lights coming on ?
    does the windows splash screen appear ?
    does the manufacturers logo appear when switching it on ?
    if you connect a computer monitor to the screen plug on the back/side of the laptop and then switch it on, does the monitor show a display ?
    do you hear any beeps ?
  • 41 Answers
It might be two problem either it might be a fault in hardware or it might be a problem in software ,,,try to boot the computer with the computer ,,,,,and try to repair the compuer frm OS cd and it will work ,,,,,,,
Posted on Jul 22, 2009
Why is facebook not opening on this system
It sounds like you have it blocked, You may want to turn off your firewall. To do that if using
Windows XP:Start/Control Panel/Switch to Classic View/Windows Firewall turn off firewall.
Windows Vista:Start/Control Panel/Switch to Classic View/Windows Firewall/Turn off firewall.
Windows 7:Start/Control Panel/View By Large Icons/Windows Firewall/Turn off firewall.
You may want to disable your anti virus protection for a short time to ensure its not the anti virus.
If this does not help contact Facebook,
Mar 29, 2011 | Computers & Internet
Firewall set to high
If using Windows XP: Go to Start/Control Panel/Switch to classic view/Windows Firewall/Turn off Firewall.
Windows Vista/7 Start/Control Panel/View By Large Icons/Windows Firewall/Turn off Firewall.
Mar 24, 2011 | Netopia 2247NWG-VGx Wireless Router...
My new hp pd0800s is not detecting please help me
For XP
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears. Your disks and volumes appear in a graphical view and list view. To customize how you view your disks and volumes in the upper and lower panes of the window, point to Top or Bottom on the View menu, and then click the view that you want to use.
For windows 7 / vista
1. Click on Start
2. Enter diskmgmt.msc into the search field
Mar 04, 2011 | HP PD0800 80 GB USB 2.0 Hard Drive
NEED TO GET BY THE WINDOWS XP PASSWORD I FORGOT
If this is a power-on password you need to get around, try the following:
1. Power down your system.
2. Power on the system.
3. Tap F8 as the system powers on.
4. Choose "Start Windows in Safe Mode with Networking" (or any "Start Windows in safe-mode" option. Networking just gives you internet support).
5. When the windows login screen appears, you may have another account available called Administrator.
6. Click on the Administrator account.
7. When the desktop comes up, go to START > Control panel > Users and Accounts
8. You should be able to find your normal account you login into.
9. Depending on the settings, you may be able to view information within the Users and Accounts control panel. I believe there is a way to view passwords, or remove passwords from accounts from within the Administrator level Users and Accounts control panel.
10. Locate your account and view the settings. You should be able to remove or view your password. (Circumstance varies in this regard, as the results depend on whether the administrator level of the control panel has been restricted or the options modified in any way previously).
11. When you are finished, power down the system normally.
If there is no Administrator account when the windows login screen appears after starting in safe mode, this feature is disabled and you can not access the administrator account from a safe-mode start-up.
Jan 10, 2011 | Computers & Internet
Windows wont work with switch, but will work with modus
Hello lets start by checking the fuse panel marked power windows remove the fuse check the view wind in the fuse if blown replace with the same amp fuse this should restore power to your switch
Jan 03, 2011 | 2001 Pontiac Aztek
When I try to boot up it says windows did not start properly and it just keeps rolling this screen. It flashes to the windows xp for a second and then goes back to the screen saying it did not start...
Try restore pc to factory setting. here is the way : http://support.gateway.com/s/software/microsof/Vista/7515910/7515910su12.shtml
Or follow this without picture is the same info:
Restore from Factory Default
The Factory Default installs a new copy of Windows Vista™ on the computer. The installation restores the computer back to the factory installation of Windows Vista with all the drivers and programs that originally came with the computer.
Notes:
  • Be sure that you back up your data files before performing this option. All of your personal data files and applications are erased during the recovery process.
  • Due to the large number of virus and Spyware threats on the Internet, it is recommended that you disconnect all Internet connections before performing the recovery. After the recovery, antivirus and firewall software can be installed, and then the Internet connection can be re-enabled to update the antivirus definitions and perform Microsoft® Windows Updates.
  1. Remove all CDs or DVDs from the optical drives.
  2. Turn off the computer, using the normal Windows shut down process.
  3. After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
  4. Turn on the computer. After the Gateway BIOS logo appears, press ALT+F10. The easiest method is to hold down the ALT key and repeatedly press the F10 key. Note: There is no prompt to press Alt+F10.
  5. Windows loads files.
    View Picture
  6. The Please wait a moment screen is displayed.
    View Picture
  7. In the Restore from factory default dialog box, click Next.
    View Picture
  8. In the Destination Disk Information dialog box, click Next.
    View Picture
  9. In the Notice dialog box, click OK.
    View Picture
  10. The hard drive partition is created.
    View Picture
  11. The factory default installation is copied to the hard drive.
    View Picture
  12. In the Finished dialog box, click OK.
    View Picture
  13. The Please wait a moment screen is displayed and the computer restarts.
    View Picture
  14. Windows prepares to start for the first time. This may take a few minutes.
    View Picture
  15. Windows continues setting up the computer.
    View Picture
  16. The computer restarts.
  17. In the Set Up Windows screen, click Next.
    View Picture
  18. In the Please read the license terms screen, select the I accept the license terms check box for each item, and then click Next.
    View Picture
  19. In the Choose a user name and picture screen, enter the appropriate information, and then click Next.
    View Picture
  20. In the Type a computer name and choose a desktop background screen, enter the appropriate information, and then click Next.
    View Picture
  21. In the Help protect Windows automatically screen, click Use recommended settings.
    View Picture
  22. In the Review your time and date settings screen, select the appropriate settings, and then click Next.
    View Picture
  23. In the Select your computer's current location screen, click the appropriate option.
    View Picture
  24. In the Thank You screen, click Start.
    View Picture
  25. Windows checks the computers performance. Depending on hardware, this process can take up to 15 minutes to complete.
    View Picture
  26. Windows prepares the desktop.
    View Picture
  27. The Gateway Recovery Management is installed.
    View Picture
  28. Installation is complete.
Dec 23, 2010 | Gateway LT2001u Netbook
Windows XP won't start
Try starting it in SAFE MODE. Hit F8 slowly repatedly as it starts before windows screen comes on.
When you get into safe mode, drivers that may be failing are not started. Then you can look at the boot log to see what failed and remove that item so you cana restart normally.
You may have a virus.
IF you have created a restore point, restore while you are in SAFE MODE.
Oct 26, 2009 | Computers & Internet
I have IBM R40 Laptop
Try pressing the power button next time. That will help you to turn on from an Hibernation.
Alternative you can disable this feature (not recommended for laptops)
  1. Open Control Panel.
    • On the Windows XP default Start menu, click Control Panel.
    • On the Windows XP classic Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, open Power Options.
    • If the computer is in Category View, click Performance and Maintenance, and then click Power Options.
    • If the computer is in Classic View, double-click the Power Options icon.
  3. In the Power Options Properties dialog box, click the Hibernate tab.
  4. On the Hibernate tab, clear the Enable hibernatation check box, click Apply, and then click OK.
Jan 10, 2009 | IBM ThinkPad R40 2897 Notebook
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
Windows start up
Wait for the chkdsk to complete and let the windows start normally. If you still have the same problem then you have errors in the hard drive or the windows is corrupted because of improper shutdown. Follow the following steps which will restore your system and you will not loose any data ;
  2. Turn off the computer using the normal Windows shut down process.
  4. Turn on the computer. To start recovery, at the prompt press the F11 key.
    View Picture
  5. In the Systems Restore Options dialog box, select Non-Destructive System Restore (Recommended), and then click Next.
    View Picture
  6. Files copy.
    View Picture
  7. In the System Recovery dialog box, click Restart.
    View Picture
  8. The computer restarts into Windows.
  9. Installation is complete.
Aug 22, 2008 | Gateway MT3705 Notebook
HP Pavilion dv2000t Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
