Question about Toshiba Satellite A35-S1592 Notebook
A35 s1592 battery won;t charge
Have a toshiba satellite a35-s1592 notebook. Battery does not charge while connected to AC adapter.. In fact while connected to Ac adapter battery discharges!! any ideas will be greatly appreciated. oh and by the way I already updated BIOS so that didn;t help
    Problem Solver:
  • 9 Answers
You probably have a problem with your power adapter. Since you mentioned that the battery discharges when connected to the adapter, it means that the charger is acting as a load instead of the other way around. This is a typical behavior of a defective charger.
Try to check the output of your adaptor using any voltmeter. The voltage reading should be approximately close to the voltage rating as printed at the back of your laptop. If not, then its wiser to buy a new ac adapter instead of sending it for repair to electronic shops. Most of these chargers are no longer reliable when repaired, and might cause more problem to the laptop instead.
Posted on Nov 13, 2008
Problem with removing motherboard battery
I would use a small flat head to push on one of the latches on the side to release the battery
Oct 21, 2012 | Toshiba Satellite A35-S1592 Notebook
I can not find Harddisk in Toshiba Satellite A35-S1592 PC Notebook,Pls help me now I can not open data in Harddisk.Thank so much for read.
You can purchase an external hard disk casing to plug in your hard disk and extract the data on another PC.
Mar 08, 2011 | Toshiba Satellite A35-S1592 Notebook
Where can I buy a new battry fo my labtop Toshiba A35-S1592
You can buy new batteries at the below link
http://www.laptoppartsshop.com/models/original-Battery/Toshiba-Satellite-A35-S1592
and also
http://www.amazon.com/Toshiba-Satellite-A35-S1592-Notebook-Replacement/dp/B0016WFPVA
Jul 02, 2010 | Toshiba Satellite A35-S1592 Notebook
My laptop's bratty A35-S1592 becomes empty after so what is the p
The cells in the battery have become degraded. You need a new battery i'm afraid.
Regards.
Toshiba satellite A35-S1592... Does it have bluetooth capability
I looked up the specs on the internet, and it doesn't have bluetooth capability. You would have to contact Toshiba or a repair shop to see if it can be added.
Mar 13, 2010 | Toshiba Satellite A35-S1592 Notebook
How do i get to the disk drive on a toshiba satellite a35-s1592
hi there is usally a plate on the bottom of the laptop ,remove it which will more than likely give u access to the hard disc drive,check for a lever or maybe a button to release the hard disc drive then download your models manual from http://www.toshiba.com will have everything u need to know u
Mar 11, 2010 | Toshiba Satellite A35-S1592 Notebook
AC port broke.
You can buy them but,
These guys do a great job. I've used them 4 times.
http://www.pcrepairhelp.net/
Oct 19, 2009 | Toshiba Satellite A35-S1592 Notebook
Toshiba A35 S159
you forgot the most important item in the whole equation the battery.How long will the computer stay on with the battery?One quick fix,try using a toothbruch to clean the contact on the battery and on the computer.This might work.I think the computer is fine. The battery might be bad,
Sep 28, 2009 | Toshiba Satellite A35-S159 Notebook
My Toshiba Satellite A30 laptop keeps switching off when charging. It works fine when on the battery but seems to overheat when I use it whilst charging the battery. Can you help ?
I would suggest that you try it with another AC adapter first, because it seems the adapter is faulty and therefore supplying more current into the laptop than necessary.
If it works perfectly with another AC Adapter, then you might just have to change your AC Adapter.
Hope it helps.
Jul 05, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Powering off
Actually, if it is beeping as though the battery is low even while it is plugged in, it is because the battery is no longer any good and is sucking all the power from the wall. You need to purchase a new battery. Until you get a new battery, you can simply remove the battery and use the laptop plugged in. That will stop it from turning off. Been there - done that. Hope that helps! ; )
Nov 05, 2008 | Toshiba Satellite A35-S1592 Notebook
Toshiba Satellite A35-S1592 Notebook Logo
261 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
