Question about Photography
Can't take pictures
Shutter button appears not to be working, or only very intermittently
  • 1 more comment
  • Anonymous Nov 23, 2008
    I just purchase the camera from a user on eBay and installed a new battery, but the shutter is not working at all. There is a small click noise, but nothing happens. I tried it with the mirror lock up and down, but nothing. I followed all of the user guides sugestions, but nothing. Appreciate if anyone has any sugestions....
  • KJ1971 Nov 26, 2008
    I have Minolta Maxxum 300si for the past couple of years, but just recently the shutter stopped working and am unable to click any pictures. Please let me know what exactly might have gone wrong? Thanks. KJ
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Which camera are you speaking of, make, model?
  • 48 Answers
This may seem really silly, but have you checked the batteries, low or weak batteries is the most common cause of problems in cameras.
If the battery is old or low in power it may have enough for you to switch the camera on but not enough to actualy operate.
Posted on Nov 16, 2008
Sigma sd14. err 1 appears after i press shutter camera makes a beep but no pic
Your camera requires service, this problem will only get worse.
Dec 22, 2012 | Sigma SD14 Digital Camera
Press shutter releas button for error are coming ,wat is the Problem
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR ' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR ' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR ' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR ' with a different Canon lens attached, then the camera should be serviced.
Nov 17, 2010 | Nikon D40x Digital Camera
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
When i turn the camera on the flash pops up and it takes a picture and keeps taking pics until i power it down. it does this intermittently depending on the settitn i turn it to.
you may need your camera cleaned. If you have taken more than about 5000 pictures with it or if you have been eating at some point and taken pics without washing your hands it could be that your shutter button is getting stuck. Some settings are set for continuous shooting and as long as you have you finger on the shutter button the camera will continue to take pictures
May 09, 2010 | Canon EOS Rebel XSi Digital Camera
When I try to take a picture with my Pentax W60, it will focus but not take the picture no matter how long I hold the button
I have the same issue, no message appears - every now and again after I push & hold the shutter button (sometimes 4-5 times, 5-10 seonds) it will finally take the picture. But, again - once it focuses it doesn't take the picture when the shutter ****on is fully engaged.
Apr 10, 2010 | Pentax Optio W60 Digital Camera
My the shutter release button isn't working
I'll give you a couple: 1. Is your mode in shutter priority or focus priority? Check your menus and go into the AF area to see which one it is. If it's in focus priority you will have to be focused on a subject before the shutter releases. The other setting is 'release priority' which will enable you to snap the shutter regardless if you're focused or not. If you tried to re-compose the picture you were trying to take, you may have locked in focus and then when you re-composed it was not in the same area thus not releasing the shutter.
2. 2 button re-set.
Jim Silva
Jun 19, 2009 | Nikon D40x Digital Camera
Error 99 in Canon EOS 350 D
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My camera seems to short out and there are horizontal lines in the pictures.
get new batteries, if recharging your current batteries does not work (to stop it shorting out).
reduce your shutter exposure, by changing to Manual Mode (M), selecting +/-, and then the left button (flash) around the Menu OK button. Mine works fine at 1s shutter speed, but was showing horizontal lines before that ...
Nov 10, 2007 | Samsung Digimax S800 Digital Camera
No pictures recorded/black screen
it seems that shutter blades are stucked and are not working. when you say shutter is fully open i think you are talking about the lense cover, not the internal shutter assembly. the red light is the indication of OUT OF FOCUS SUBJECT OR FLASH NOT READY. if the shutter blades aare not open the camera would not be able to do the focusing and will flash the red light thus you would not get any image. contact the repairer.
Jun 20, 2006 | Kodak EasyShare LS443 Digital Camera
Photography Logo
202 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
