Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Water leak under my hoover steam cleaner
When I turn on my steam cleaner the water pours out from underneath. I see there is a white hose inside. I do not know how to remove the bottom plate to see if the hose is broken. I removed 4 screw but this did not see to do the job. I do not want to break the plastic plate. Please help.
  • 107 Answers
Sounds like you have a bad solenoid.
Posted on Dec 09, 2008
Why does water pour out the back when I use carpet steam cleaner
Hey there! It sounds like your cleaner is leaking. That can mean an issue with your pump assembly. We recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jul 01, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover spin scrub 50 leaking from bottom
Uh, may I encourage everyone to check the trigger under the handle...we went through taking the whole thing apart and it was just that the trigger was stuck in the open position, which poured the water out continually!
Apr 09, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Repair hoover steam vac F7210
Fixya does not make servicing recommendations.
Jul 23, 2017 | Vacuums
Hose that releases the water and cleaner on my Hoover is clogged
Your right the hose is clogged.. Use a portable vacuum to blow the dirt inside the hose.
Jul 24, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
My Hoover Carpet Cleaner is leaking out the bottom when I use the hand tool
this could be the little white valve that the water comes out of, if its leaking from here or if its leaking at the bottom of the machine it could be the pump
Jul 19, 2009 | Hoover F5906-900 Upright Steam Vacuum
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
HOOVER STEAN VAC 2 DEEP CLEANER
If you used any other cleaning solution other than Hoover, your Steam Cleaner will develop deposits in the turbine that drives the brushes. What happens is this:
Users pour other store bought brand cleaners in the reservoir to clean. Then they store the Hoover Steam Vac. While sitting in storage, the residue dries in the turbine and develops hard deposites, which ruins it. It will cost you about $100 to have the Hoover Store repair.
Cleaning Solution:
http://www.amazon.com/dp/B0002B8L26?smid=ATVPDKIKX0DER&tag=yahoo-kitchen-20&linkCode=asn
Oct 14, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Problem hose
Try gently feeding a thin, springy wire down the tube to find is there is a blockage further up.
Mar 22, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
382 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
