Question about Symbol LS2208 Handheld
Scanner doesn't turn on
Hi, I have Symbol LS2208 Scanner. When I connect to the PC it doesn't turn on, am I missing any steps to turn it on? Please help, tnx
    Scholar:
  • 117 Answers
Hello Loverboy,
the scanner turns on automatically as he he receives power from the host interface.
Please check the cables and connection. For RS232 interface would you need an external power supply. USB can power the scanner without external power supply. By Keyboard Wedge installation please connnect also the Keyboard.
Posted on Dec 07, 2010
I have got a LS2208 scanner connected by usb. The scanner was manufactured in 2006. When I do a test scan in the OPOS software it works but does not work on notepad or word. Please advise.
Open a dos command window and see what data is inserted there. It should show the barcode and either step to the next line (If Enter is inserted by the scanner). If you are not getting anything in the dos window is it actually a USB scanner ?
Mar 01, 2011 | Symbol LS2208 Handheld
Hi my name is christian canola and i purchased a symbol ls2208 barcode scanner from geminicomputers and i downloaded the program 123 scan2 for my barcode scanner and i click on my scanner is connected via...
Hi Christian, if your scanner was manufactured before February 2010 it may not be able to communicate directly with 123Scan2 so you wont be able to upgrade firmware with the program, but you will still be able to use it to create configuration sheets. These are the only two uses for 123Scan2.
To create a configuration sheet without "finding" the scanner click Create New Configuration then choose My scanner is NOT connected. Select the LS2208 and click on the blue firmware button to get into the configuration. When you have completed your configuration click the Print bar codes selection at the top of the window and when the file comes up be sure to click on the Bar code formatting menu and change the Bar code type to 1D One setting per barcode if it is not already there. Older scanners will not work with concatenated 1D barcodes where 123Scan2 puts more than one setting into a barcode.
Feb 12, 2011 | Symbol LS2208 Handheld
Hi can u tell me that symbol scanner ls2208 will work on ATS
The LS2208 is a universal scanner with many supported interfaces. Please check the ATS if one of the interfaces are available. See the list below:
RS-232 IBM 468X/469X Keyboard Wedge Wand Emulation Undecoded Scanner Emulation USB Synapse Adapter
Oct 28, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
Switching rules Symbol LS2208
Hello Jonathan,
you would need to assign the rules to a specific ruleset. Then you switch between the ruleset to specify which rules are active at the moment. Please see the ADF chapter in the Reference Guide for LS2208 for the barcodes http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Apr 27, 2010 | Symbol LS2208 Handheld
Can't install Symbol LS2208 barcode scanner on a PC (Wedge cable)
You will need to scan the barcode that configures the LS scanner to use keyboard wedge or even the set all defaults barcode. You will be able to find both of this on the product reference guide that you can download from www.symbol.com in the support page.
Mar 14, 2009 | Symbol LS2208 Handheld
LS2208 works - Keyboard does not
Check that the wedge is good. It is basically a hybrid spltter that powers both the scanner and the keyboard.
USB keyboard?
If so, you may want to go direct to either a serial port or a USB direct connection
Feb 24, 2009 | Symbol LS2208 Handheld
How to integrate LS2208 handheld scanner in vb.net
you have to change it to IBM handheld mode and install opos drivers from symbol. then use pos.net to connect to them.
Some computers requires to create some config files to connect through hardware address. It took me like 6 month to figure out but now it works
Nov 06, 2008 | Symbol LS2208 Handheld
Barcode scanner Symbol LS2208
I had the same problem with LS4278, you need to configurate your keyboard and scanner in the same regional and language options
Oct 20, 2008 | Symbol LS2208 Handheld
Symbol LS2208
Hi
This link will show you how to append tabs after each scan
https://docs.symbol.com/attachments/ADC-01492.doc
Above link is dead but this seems OK
https://goo.gl/0xuCx5
Aug 08, 2008 | Symbol LS2208 Handheld
Symbol LS2208 barcode reader no data to screen
Just because it has a DB9 does not mean it is a direct connection. Many Bar code scanners have the DB9 connecting to a interface box and the interface box connects to the PC. If it is really a rs-232 scanner then you need to configure your serial port to the proper settings specified by symbol. But I am confident that this unit is missing the interface box.
Jun 27, 2007 | Symbol LS2208-7AZK0100S Handheld
Symbol LS2208 Handheld Logo
326 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
