Question about ASUS A6U Notebook
USB PROBLEMS if I connect a flash or my external HDD in one of USB ports (doesn't matter witch one) and I want to delete a file, or write on this device, I receive the message 'IT'S WRITE PROTECTED", but I know that is no protection on my device because on other coputers it runs ok. Many thanks, Silvia Medinschi
  • 152 Answers
If it runs ok on other computers and if it isn't on yours then it is surely a driver problem... try updating the driver using device manager...
Posted on Nov 09, 2008
Pc wont recognize my hp simplesave 2TB external hard drive
No PC stated
No OS stated. (operating system) nor if PC is internet connected.
no Simplesafe model stated, is it the 3.5" HDD? version
id yes it needs power pack to use it. HDD uses huge currents to start up. and spin.
USB ports?
if the drive fails on all PCs, the drive is bad. (or was erased by grimlin's in the night)
plug in the power pack 12vdc is correct.
do not mix it up with other packs or boom.
then listen to the hdd case with you ear, here it spin up?
if not the pack is dead, or the hdd is dead.
here is the power pack for it sold in stores
see that model number there you forgot, to mention, MD2....~~~~
12V Mains AC-DC Adapter for HP Simplesave 2TB MD2000HB External Hard Drive HS....
the drives can fail and be good.
for many reasons.
  1. bad usb port
  2. usb port driver missing.
  3. OS virus corruptiong
  4. drive fails to spin means no 12vdc power. (bad power pack)
  5. using a laptop and expecting the weak USB ports to start HDD motor, will never happen, on large 3.5" HDD. some cant even start a 2.5"
http://www.pcdied.com/external-hdd.html
Aug 24, 2017 | HP SimpleSave 2 TB USB 2.0 Desktop...
My hddr640e04xr is not detected
You don't need to have a driver for your external HDD to work.
You have three possible problems:
1. USB port (software problem) - outdated USB driver or with bugs
Try updating them via the device manager. Or you can try uinstalling it then scan for hardware changes. It will automatically reinstall.
2. USB port (hardware problem) - try a different USB port.
3. HDD defective - You may want to try connecting it to a different computer. If it doesn't work in a different computer then it should be defective.
David
Feb 20, 2013 | Computers & Internet
Won't link to my computer and flashing red light inside.
Is this a new one or have you used it for some time? If it is a new one, it might not be getting enough power to work.
If you connect it through a USB hub, disconnect the hub. Connect the HDD directly to the computer and see.
If it doesn't work, find a USB cable with two USB jacks on one side. Connect both to USB ports at the back of the computer (and of course, connect the other end to the HDD) and see.
Best of luck!
Aug 31, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Hy my problem is that whenever I connect my External Hdd in the computer,It doesn't show anything.The device is working beacause it's light flashes when i connect it.When I buyed it it worked.I...
Hi ludovicungur,
If your device is blinking fast then it means the problem could be that your are using an incorrect mode of connection for e.g. a USB extension cord , or a USB hub to connect your external HDD.
I would suggests you to remove any external cable or USB hub and then connect the hdd directly to the port on *********** board ,if possible try changing ports and it should work.
Hope this helps ..:)
May 10, 2011 | Office Equipment & Supplies
Usb2.0 poort
USB 2.0 port on your computer is intended to make connection to external data like flash disk, camera, external HDD, handycam etc. Just connect your external data on usb port and see them on your computer dispay.
Regards
Mar 23, 2011 | Computers & Internet
3.5 HDD external enclosure
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you don’t do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to check the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. Ensure that you have set removable drives for "quick removal" or that you use the "Safely Remove Hardware" option often shown on the lower toolbar. It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! And knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click of Death"
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Mar 23, 2010 | Western Digital imicro IM35ST320SI 3.5 IDE...
Exernal HDD Problems
With your external HDD connected to your PC. Switch it on, and from the menu, left click Setting, Control Panel, Add Hardware wizard. Right click on it to open. This is for you to know if your External HDD is installed, and working properly. If not installed, you can follow the instruction prompted to have it installed. Better still if you have the CD disc installer software for Iomega HDD External Desktop, wherein you can put the disc at at your CDROM and install the software. Otherwise, you can get a driver software
from the Internet. Get your PC connected to the
Internet, and type at the Search engine blank (Download for a Driver software for Iomega HDD External Desktop (32660)) . Once you finished your
download, go back to your PC menu, and find your
download. Click on it open and install your software.
Hope this help you.
Nov 26, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Cannot copy files directly to WD external 250gb HDD
Ensure you are on a USB 2.0 port ! that is most important
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
You should also do this to cheack the drives connections are not bad inside the enclosure
Known as "The Click Of Death"
Oct 02, 2009 | Western Digital 250GB MyBook External USB...
External hard drive problem
The problem is that the printer, being a composite device, takes a lot of energy from the computer USB ports. Some computers, such as some Dell computers, have problems with USB ports due to a cheap manufacturing. What I can suggest you is to simply unplug the printer when you want to use the HDD, because no matter what you do, you'll have the same problem and that's because of the computer that won't supply enough power to the USB ports.
Also, if you are using a laptop, remember to keep it plugged to the power so it can provide more energy to the USB ports.
Aug 06, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Unable to connect USB hard drive to KD-AVX33
I bought this model also. It depends how much power the external drive uses. The models with 2 usb cables usually don't work because they require more power.
The hdd cannot be bigger than around 20GB, not more then 12 folders and no more then 2500 files. I saw at some forums.
If you have a pen drive at 8 to 12 GB i don't think you have problems with these. anything bigger and you have to be lucky.
Maybe at my company i can try some drives as we have them to test/use.
Nov 05, 2007 | JVC KD-AVX33 Car Video Player
ASUS A6U Notebook Logo
203 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
