Question about Miele Washing Machines
Water leaking from filter area of Miele W427 washing machine. Machine empties OK, most water is discharged as normal however, approx 1-2 ltrs leaks from filter area. The filter is clean and no blockage can be discerned once filter is removed. Tried the Just Answer website, they took my money and never responded, can you do any better? Rehards simon.chapman@btinternet.com
  • 2 more comments
  • balladacfe Nov 09, 2008
    First response doesn't address actual problem. repeat problem: Water leaking from filter area of Miele W427 washing machine. Machine empties OK, most water is discharged as normal however, approx 1-2 ltrs leaks from filter area. The filter is clean and no blockage can be discerned once filter is removed. Note leak from filter area where there is no washer.
    further detail. Following completion of wash cycle, there is a pool of water on the floor. Also, when opening the filter area a build of water is released. This would suggest a blockage however, the volume of water spilled is only a fraction of what the machine will have used, suggesting only a part blockage if at all. Also, by inseryting finger into escape and hose no bloackage can be discerned.
  • balladacfe Nov 10, 2008
    After a wash the majority of the water is discharged, there is a small amount which has leaked on to the floor. When removing the filter a back log of approx 2 pints of water is released. Using a screwdriver I can spin the pump accessed beyound the filter. With the filter removed and putting the machine in drain mode the pump rotates. Could it be that the pump is working, but not fully?
  • balladacfe Nov 11, 2008
    several suggestions provided and while very interesting they don't address the issue.
  • Miele Master
  • 19,396 Answers
I quote from you to resume your problem with your own word :
"Water leaking from filter area of Miele W427 washing machine. Machine empties OK, most water is discharged as normal however, approx 1-2 ltrs leaks from filter area. The filter is clean and no blockage".
And
" Following completion of wash cycle, there is a pool of water on the floor. Also, when opening the filter area a build of water is released."
You say the filter is ok, than there are few possibilities.
1 Since the machine leaks during the drain cycle only (that is what I understood) the most likely is a problem with the drain lines.
Teh repairman will access the inside of the machine, and inspect the drain lines to see where the leak comes from.
The drain hose can also be obstructed, you can blow some air into the drain hose to see if it is clogged.
2 The drain pump is faulty and is leaking. A faulty drain pump can leak, this can also explain the two pints of water. Again, there is the need to observe the pump and see if it is leaking. The pump is mounted on the lower side of the appliance, watching ftom the front on the right side.
3 The machines is overfilling and it is leaking some water from the main tub gasket. I do not think this is the case, but it is also a possibility.
Here you find generic schematics.
Posted on Nov 11, 2008
  • 83 Answers
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
    President:
  • 1,952 Answers
You how to take the unit apart to replace a coupler, This will show you how to remove the front and both sides to expose the workings, there you will probably find a pump leaking, the tub to pump hose leaking,
Replace the air gap connecting tee
If the hose ruptures, large quantities of water could gush from the hose. If it's the hot water hose that ruptures, the gushing hot water may scald anyone nearby.
For more peace of mind, one alternative is to use high quality stainless steel fill hoses. You can find them in our Accessories section under washer/dryer. In addition, we carry the black rubber hoses supplied by the manufacturer, use our PartDetective to locate the ones for your unit. And, universal washing machine hoses, also in our accessories section.
Posted on Nov 09, 2008
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Nov 09, 2008
  • Air-gap
    device -The air gap is a small device found on most washers that
    prevents the wash water from being siphoned into the household water
    supply. It's located either mid-way along or at the end of the black
    rubber hose that comes from the water-inlet valve. Often it's made of
    translucent plastic. If one of the air-gap components deforms or
    cracks, you may need to replace it.
  • Hot and
    it, as appropriate.
  • Main tub seal - The main tub seal
  • Pump
  • Outer tub -
    mohammed marika thambi Nov 11, 2008
    bottom of the machine rather than from the control panel.
    water level in comparison to the heating element
      President:
    • 2,712 Answers
    I would check these first:
    • Loose bolts in the tub - tighten them. Your fill hoses might need tightening at either end.
    • A leak in the main drain hose. Inspect the entire hose and correct any problem you find.
    • Poor draining in the standpipe causes the sudsy water to back up and overflow, making it look like a washer problem when, in fact, it was a plumbing problem.
    • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
    • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
    • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
    • Very restricted water flow through the valve. Low water flow will cause the water from the valve’s discharge hose to run back up the hose by capillary action and down to the floor. This is a tricky one to catch.
    Let me know how it goes..
    • Swilin Sampson
      Swilin Sampson Nov 10, 2008
      Yes, it could be the pump or any of the other things i mentioned. The only way to be sure is follow the steps to check which part is faulty..
      Sergeant:
    • 229 Answers
    To start try filling your machine up at the lowest level it will allow and then let it cycle. If it does not leak at that point it probably means that the machine may be over filling at some point (if this is a front load machine this will be a moot point). If overfill is not a problem then your machine is leaking internally while it discharges the water. I had a machine that did this and there was a coupling in the back interior of the machine that had to be replaced. It is definitely worth repairing or having the machine repaired since it will probably be fairly inexpensive. If you are mechanically inclined remove the back of the machine and check for leaks near and at the coupling where the drain pipes are located. Good Luck Hope this helps.
    • Lance  McKinney
      Lance McKinney Nov 09, 2008
      Also there sometimes can be split hoses near the coupling on the exterior of the machine that will cause water to get into the machine as well. Check both exterior and if that fails be sure to check the coupling on the interior as I described before. Good Luck!
      Sergeant:
      Novelist:
    • 196 Answers
    Check the easy stuff first, fill hoses tight?- drain hose cracked?
    Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
    • mmechanics Nov 09, 2008
      read this instructions carefully
      Even if the appliance does not appear to have
      water inside the
      drum area, typically 2 quarts of water can
      still be drained from the
      appliance via the Manual Drain.
      Always have a suitable container
      ready for the water.
      1. Open the Filter Access Door.
      2. Place a
      suitable container underneath the Drain Tube.
      3. Turn the
      Filter Cap counterclockwise 2 - 3 times. Do not
      completely
      remove the filter.
      Service Tip:
      In the event the container being used becomes filled, simply
      tighten
      the filter (clockwise) to stop the water flow. And
      repeat steps 2-3
      until no more water drains from the tube.
      Once the water stops flowing…
      5. Continue
      turning the filter counterclockwise to remove.
      6. Clean out
      any foreign objects or lint from the filter.
      7. Check that
      the Drain Pump Impeller (in the back of the
      chamber)
      rotates freely by spinning with your hand.
      8.
      Remove any detergent deposits, excess water etc...
      9. Ensure
      the filter threads are clean, and place filter into position
      and secure by turning clockwise.
      and also
      You can replace the Bellows as it is called but to fix it before you replace it
      clean it with Bleach to kill the mold and then dry it ALSO after any load you do
      leave the door open a bit this allows the mach to air dry out and prevents the
      build up of mold .
    My machine is leaking from the bottom of the machine.
    The water fill solenoid hose may be leaking or any of the other hoses involved in operation Sears Online In Store Shopping Appliances Clothing More
    Sep 22, 2017 | Washing Machines
    Why does my water container fill up even though my machine is plumbed in?
    This looks like a fault. The plastic tank has two reed switches that measure 'tank empty' and 'tank half full'. When the tank is empty the inlet solenoids (there are 2 for safety) open and water enters the tank but not so much to fill the tank to the half way level. In normal operation the level water in the tank will drop and then more water is allowed in. In your case it appears the 'half full' reed switch is being activated because the solenoids are not closing off properly and water is leaking in and filling the tank. If you do not empty it then eventually it will fill and leak into the leak. The problem can be caused by either low water pressure (below 145 psi) or sticky solenoid. If is the solenoid then the Miele solution will be to replace both solenoids. Alternately you may be able to remove, take apart and clean. Also check that you have a mesh filter at connection to tap. Also you can temporarily fix the problem by turning off the water at the tap and re-programming machine to 'turn off' the plumed water line. regards
    May 31, 2014 | Miele Coffee System
    Water leaking into soap dispenser when machine off
    faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
    Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
    Miele leak when switched on for wash, from filter unit front LHS bottom of machince
    The leaks in a washing machine could be coming from many different places in the washer.
    The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
    The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
    Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
    If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
    Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
    When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
    Aug 06, 2008 | Miele Novotronic Premier 500 Front Load...
    Leak from Novatronic W310
    Bit the bullet and stripped out the covers from the unit so as to observe where the leak was coming from. Ran m/c on a basic quick wash (be careful, exposed live electrical terminals!!!) and noticed that water came from the detergent drawer for a second or two.
    Stripped out detergent drawer housing and found that the large discharge pipe underneath was very blocked with black/white residue. Presume that this had been dislodged from the walls of the pipework during the house move.Removed residue and reassembled unit & ran, OK.
    Saved myself £100 call out. Give Miele their due though, the documentation suggests that if you habitually wash at a low temperature, which we do, you should occasionally run a 95degree wash. My wife was very surprised when I asked her if she did this.
    Apr 21, 2008 | Miele W310 Front Load Washer
    Miele washing machine model W713 front load - issues
    If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
    Sep 13, 2007 | Washing Machines
    Miele novotronic w/m fault light flashing
    We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
    May 07, 2006 | Miele Novotronic Premier 500 Front Load...
    Washing Machines Logo
    102 people viewed this question
    Top Miele Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    mpservices
    Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
