Question about Hotpoint 23 in. BFI68 Built-in Dishwasher
Hotpoint BF 168 Dishwasher
I switch on the dishwasher and everything appears normal. You can hear water entering the machine but once it reaches the point were you would expect to here the water jetting out of the rotating blades.... nothing! Opening the door you find that light 4(Soaking) & 5(Crystal) are lit. These lights are not responding to the usual escape measure, i e holding down program button for three beeps and then resetting, and the only way to get the lights out is to turn off the dishwasher. I have cleaned the filters but there was a lot of water in the compartment were the filters are, I can't remember if this is normal.
SOURCE: Fault with Hotpoint BCI45 Dishwasher
This a generic problem with hotpoint dishwashers..
Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Posted on May 23, 2008
  • 157 Answers
SOURCE: HOTPOINT AQUARIUS FDW60 ECO LIGHT FLASHING
Check pump is running
Posted on Dec 19, 2008
SOURCE: Dishwasher prog light is flashing and pump is running nothing els
ok, just a few minutes after posting this as a fault, I have opened the covers, the machine has a leak, the undertray has a sensor which has detected this, flashing light (prog 45 degC wash) flashing is a code to indicate leak sensor active.
Other prog lights flashing indicate a different fault, the following details each... this is a cut/paste from another forum site, copied without permission....
jawa592rc_a04.gif on 6th Feb 2008
Cannot guarantee 100%accurate but you all might like what the flashing fault codes actually refer to, note what follows are pointers to what bit has gone wrong only. You should have the programmes running left to right: led1=intensive,led2=normal,led3=eco,led4=fast,led5=prewash,led6=delicate wash.ok so when this heap of western european tosh goes wrong one or two lights will flash this is what they mean:led3=m/ch has o/flowed water . ie the base underneath has sensed a leak.4=i/let h2o valve u/s or slow fill.5=thermister(electronic thermostat) is u/s or more likely the pcb .6=timeout heating which means the thermister senser between the door halves has become faulty or detached.3+4=no pump out,slow pump out,pcb u/s,blockage.4+5=tap off i/let valve.3+5=wash motor not coming on -seized,winding o/cic.but can also mean mesh plte filter badly blocked.1+4software fault with pcb.4+6=heating cic u/s (usually the heater tube )but can be the heater relay on pcb.3+4=pcb u/s.I don`t except any responsiblity for this being spot on or near spot on!! hope this helps someone.Try NOT to electrocute yourselves please!! If your not at all confident walk away and get "someone" who knows what they are doing.Cheers. jawa592
Posted on Jan 28, 2009
  • 3 Answers
SOURCE: Hotpoint FDW60 Flashing lights 3 and 5
Same thing happened to me.
The electrics tripped and once going again, 3 ECO was flashing.  This fault was caused by the polystyrene float rising when water fills the botton tray.  Tipping the machine onto its side empties the water unto your floor and clears the fault.  But if there is a leak, the tray will refill, usually in a few minutes, and Flashing ECO appears again.  If you remove the bottom trap - held on with six screws, you will see the float.
The fault was traced to one of the three pipes that run up the left side of the machine to a plastic box.  One had worked loose and was flooding the whole of the electrics area.  This will splash water on the mains suppressor whichs sits directly below it and will trip a RCD in your fuse box.  A jubilee clip fixed the problem.
Now, the machine runs for about 30 seconds, stops, drains and 3 and 5 flash - same fault.  It is possible the connectors are wet and short circuiting.  I suppose if they dry out over a day or so, then this will cure the problem.  I suspect that this fault is triggered by a sensor or switch somewhere - does anybody know?
Posted on Feb 16, 2009
SOURCE: Hotpoint Aquarius SDW60 Dishwasher
i have had this dishwasher sdw60 for 18 months and it just keeps beeping, i have cleaned it ,turned it off at the mains it just dont wont to work. please help.
Posted on Feb 08, 2010
After pumping out all the water, the machine just keeps on pumping and not re-filling with clean water.
see this causes and use the common sense.God bless you
If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. To determine if the float switch has failed, watch the part testing video at the bottom of this page.
Sep 19, 2012 | Hotpoint Dishwashers
Fdd914 dishwasher error code A10 appears and its not in the booklet
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
Just moved house dont know how to operate hot point dishwasher model no-bf 168
The manual for the Hotpoint BF168 dishwasher is available here: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Dishwashers/BFI68.pdf . If the direct link doesn't work, start here: http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do . Then enter Hotpoint and Dishwasher in the Browse for product drop down menus. Then scroll through th pages to find your model.
Make sure the water is on, then load the racks. Fill the dispenser with the appropriate amount of dishwasher detergent. Press the On/off button on the right of the washer control panel. Press the wash program selector (the leftmost button) until the desired program type (icons to the left of the button) has the LED light up. Then close the door. See the manual for delayed cycles and adding salt for the water softener.
I hope this helps.
Mar 14, 2011 | Dishwashers
Machine has power and appears to be running but no water is coming through
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 30, 2010 | Hotpoint 24 in. DWF34 Built-in Dishwasher
Not getting water into machine although mains water is reaching hose intake. model number of bosch is sgs44e28eu05 type si1501b
There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. thanks.
Feb 17, 2010 | Bosch Dishwashers
Wont go through cycles or drain the 3inches of water.Is getting power
turn on the dishwasher then go to your circuit breaker and, switch off the power to your dishwasher next: reach in to your dishwasher and remove the cover on your pump then remove any broken glass etc. that has fallen into the pump then put the cover back on and, close the dishwasher turn it on and, turn on the breaker you turned off earlier your machine should work again let me know how it goes...
May 02, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Hotpoint DF32 Dishwasher
I have a similar problem.When the water stops entering,I momentarily turn on my main kitchen cold water tap, and believe it or not,the machine carries on working!!
Nov 04, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Open Questions:
See all Hotpoint 23 in. BFI68 Built-in Dishwasher Questions
Hotpoint 23 in. BFI68 Built-in Dishwasher Logo
253 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
