Question about Maax Shower Drain 10000041-105
Leaking maax shower drain, can I remove the grate and seal it from the inside?
  • richardcharn Nov 15, 2008
    got it fixed, figured it out, the drain grate pops out, then a rubber collar, with an expansion sleeve, just took it apart, cleaned well and put silicone in before reassembly.
  • Anonymous Mar 26, 2014
    Can I install a maax fibreglass shower against the gyproc or do I remove the gyproc first
  • 61 Answers
Try this:
you might but it will depend if it is pvc then yes any other material you might be able to use a waterproof epoxy but it will harder to repair because of the epoxy but the pvc you can prime and glue the seam from the inside..
Posted on Nov 12, 2008
Is there any problem with using silicone on maax mediterrian III shower walls
I looked at the installation instructions for mediteranean III at this Maax site. It says silicone sealant is to be used. Unsure where you noticed mentioned of siliconized latex.
Sep 04, 2014 | Maax Breeze: One Piece Round Shower...
How to remove the shower valve on my Maax shower? It is leaking badly, and I think I just need to get to the valve that directs water to either shower head, or back sprayer nozzles or the whole body
Its probbably the hose connected to the valve, try screwing it back on and turn the water up slowly, if that does not help, check your local radio shack
Nov 05, 2013 | Maax Brio II One-Piece Neo-Angle Corner...
Maax iris b leak in corner of fixed panel
Sometimes you have to override inadequate instructions with application of some common sense. It might be interesting to know why Maxx thinks the inside track should not be sealed. Also, test for water migration from where it should be to where it shouldn't be
Jul 13, 2013 | Home
I have a Maax Neo-Round Corner shower that leaks under the track the doors slide on. I have caulked inside & out but still leaks. Any suggestions????
You may have to remove the doors and the track and reinstall the track on top of a "bed" of caulk or sealant to prevent migration of moisture underneath. The leakage also may be caused by moisture running down the inside of the doors during active showering. Check also for warpage in the track that would cause it to seal unevenly
Nov 10, 2012 | 2003 GMC Envoy
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Nov 08, 2012 | Maax Acrylic Base for Shower - 102623
We have had our shower for 5 years now and it continues to leak at the bottom corners. we have the corner shower stall against a tile wall. I have replaced caulking several times even removing stiles...
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Nov 06, 2017 | Maax Brio II One-Piece Neo-Angle Corner...
I need to remove the Maax shower base and can not figure out how to remove the wedge retainer. do i need to actually cut the shower base to get the pipe detached to remove the shower base?
Hello, You shouldn't have to resort to that extreme. The drain unit that the retainer sits in is the part securing the base down, have a look at the diagram in this link:
The drain assembly should unthread and release the base. But sometimes they tend to work as designed.
The retainer is a compression fit (or should be... do you know the installer? they may have deviated from the described installation). Assuming a proper install, use a flat-head screwdriver and a utility knife to seperate the inside portion of the rubber seal of the retainer, from the plastic ring. The ring should now be able to be pried out, and the drain portion unthreaded.
If this helped, please rate a four-thumbs up. Thank You.
Nov 08, 2010 | Maax Acrylic Base for Shower - 102623
Maax Shower Drain  10000041-105 Logo
1,575 people viewed this question
Top Maax Plumbing Experts
Andrew Taylor
Andrew Taylor
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
