Question about Belkin Computers & Internet
Enabling upnp i have a motorola SB5100 router and a belkin wireless g router connected to it. i cannot acess the settings for the wireless to enable the upnp for the psn network. how can i access and change the settings?
    Scholar:
  • 132 Answers
You need to access the router's setup page. The default IP address of Belkin router is 192.168.2.1. Launch IE and type 192.168.2.1 on the address field. It doesn't need a username/password by default. So when a windown pop up asking for one just leave the fields blank and click ok.
Once you're in the setup page, you may now be able to configure the router with the settings you need.
Hope this helps!
Posted on Nov 14, 2008
How do enable upnp on belkin router
Since you aren't specific about the model of Belkin router you are using, I can only give you some general advice. This is what is have from MY Belkin router manual. Yours may be different....
Enabling/Disabling UPnP
UPnP (Universal Plug-and-Play) is yet another advanced feature offered by your Belkin Router. It is a technology that offers seamless operation of voice messaging, video messaging, games, and other applications that are UPnP-compliant. Some applications require the Router's firewall to be configured in a specific way to operate properly. This usually requires opening TCP and UDP ports. An application that is UPnP-compliant has the ability to communicate with the Router, basically "telling" the Router which way it needs the firewall configured. The Router ships with the UPnP feature disabled. If you are using any applications that are UPnP-compliant, and wish to take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "System Settings" page. Click "Apply Changes" to save the change.
Jun 29, 2015 | Belkin Computers & Internet
I need to change my NAT to open. It's on moderate right now. I have a Motorola Surfboard SBG900 router/modem.
first if your on windows click start goto run type in cmd and hit enter
then if your directly connected to this router/modem with nothing else in between it type ipconfig /all
you'll get 19x.x.x.x number or something like it under default gateway write it down and then open your web browser. Type in that address into the navigation bar and hit go or hit enter.
You'll get a motorola login screen.
By default factory settings the un/pw should be admin / motorola when logged in goto administrator if it's possible. Then enable UPnP and apply these settings or save.
Otherwise if your behind a router that is in between the motorola modem and your PC. do the same thing start > run > cmd > enter> black box and type ipconfig /all goto the default gateway here enter your un/pw for your router and goto administrator again enabling UPnP.
Mar 07, 2011 | Arris SURFboard SBG900 Wireless Router...
How do i enable upnp
Using your Internet browser, you can access the Router's Web-Based Advanced User Interface. In your browser, type "192.168.2.1" (do not type in anything else such as "http://" or "www"). Then press the "Enter" key.
Click login, the router comes with no password set, so unless you have changed the password, just click login.
To take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "Utilities" page. Click "Apply Changes" to save the change.
Oct 18, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hello FixYa, i've tried to open my nat for Xbox LIVE, by Port Forwarding, DMZ, UPNP, enabling NAT, what can i do to finally fix this problem?, this has been going on for 2 and a half years now.
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Aug 14, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Ive connected my xbox 360 through wired connection to my modem/router and it tells me my NAT settings are strict and to enable upnp but i dont know how to enable it?
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jul 30, 2010 | Zyxel Prestige 660HW Wireless Router...
Belkin wireless g mimo router. i never set a
When changing the advanced settings on the Belkin router, you should change the default password.
To change the password, go to Administrator Password. Type in a new password. Make sure you remember the password, otherwise, you will need to reset the router back to default settings.
I hope this helps.
Jun 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i connect ps3 to the internet using a belkin router
Hardwire your PS3 to router or connect it wirelessly by scanning from PS3....
Now hardwire your computer to any of the wired ports of the belkin router....
Goto start>run>type "cmd" >type "ipconfig" note down the default gateway address.....usually it ll be 192.168.2.1
now open any web browser and type the default gateway address in the address bar and hit enter.
In the belkin router set up page
Click FIREWALL and disable it....apply changes
click system setting and enable upnp....apply changes
click virtual servers and open the ports for PS3...and enable it...
that all...you are done with it...
you can also enable DMZ....it ll also resolves the issue....
Mar 03, 2010 | Belkin (F5D7231-4) Wireless Router
Is a Belkin N+ wireless router compatable to a Motorola modem SB5100?
No - one it is a modem, the other is a router.
The modem 'translate' the data as it comes into your network.
Routers connect computer (direct traffic).
Feb 28, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Enabling uPnP
Open the RSP by typing 192.168.2.1 On the Address bar of the internet Explorer
On the left side under utilities Click System Settings
you can Enable UPnP in this Page
Jan 06, 2010 | Belkin (F5D8231-4) Wireless Router...
I have a Belkin Wireless router and I have a PS3
Actually you don't need to forward ports when playing online games. The router should automatically locate the ports for the game because it has UPnP function. Here's what you can do. Disable the port forwarding and DMZ that you set on the router. Look for the UPnP function of the router and disable, Save it. Enable it again, then save. Now power cycle your router. If you have Static IP on the PS3 network settings, try to set it first to automatic IP and automatic DNS.
Hope that helps.
Sep 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Computers & Internet Logo
244 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
