Question about Hoover F7431-900 SteamVac Vacuum
My shampooer leaks
My shampoorer leaks when sitting idle
  • 1 more comment
  • Karen Sharbono
    Karen Sharbono Jan 08, 2009
    I have replaced the tank again and again it continually leaks. It is the unit.
    Eventually this happens; We found that no soap was dispensing, so we cleaned the rubber washers out under the tank and put back together now it dispenses fine BUT.........it empties out immediately and I can no longer use the attachment hose cause when I spray it comes out under the unit instead.
    I tell ya.....What a mess!
  • Anonymous Feb 06, 2009
    Poorly designed or manufactured tank. Appears insufficient plastic thickness around valve feed...sucks...no pun intended...
  • tbgroff Mar 13, 2009
    I think I have the same problem w/ my hoover steam vac-the water just runs out the back of the unit. I looked @ the seals & they look ok. Could you see your bucket leak?
You need a new tank old tanks cracked at the seal hoover came out wih a replacenent tank old tank will have a crack in it by the seal
Posted on Dec 01, 2008
Water leaking from carpet shampooer
Need to know where it is coming from. Inspect thoroughly to determine source of leaking water
Sep 19, 2017 | Vacuums
I have a bissell pro heat2x turbo. my problem is that the sprayer underneath is not working, also it sounds as if there is air coming from somewhere.
Sounds like there is a leak or crack somewhere in your tank.
Check the tank and tubes for damage or clogs. You may have to replace your tank.
Proheat 2X Shampooer Shampooer Parts
800-775-6586
GoodVac com
Feb 22, 2015 | Bissell Vacuums
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My pet wash bissell shampoor won't pick up the water
Hey Deanne!I know how frustrating it is not having suction when you need it.
Here's a quick link to troubleshooting steps to assist you with the suction.
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 23, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Shampooer won't pick up water
look on the vacuum where the suction is to pick up and you will see its clogged ,clean out the suction ports
Apr 13, 2009 | Kirby G6 Bagged Upright Vacuum
Carpet shampooing
http://www.greatvacs.com/shampoo.shtml
This link has photos for a step-by-step install of the shampooer.
Note: I found the most difficult part was ensuring that the belt was connected correctly, so spend a couple extra minutes in the beginning and you won't need to sit in soggy carpet working with it.
May 08, 2008 | Kirby G5 Bagged Upright Vacuum
Leaking Carper Shampooer
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much.
The manual says to "push the tank in until it snaps into place". Everything looks fine across the board so I believe this particular model is just a bad design overall.
My recomendation: Get a new carpet cleaner from Target or Wal-Mart.
Please let me know if this helps. Good luck!
Feb 28, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Kirby shampooer
You are missing the wee round suds screen that fits over the small hole on the tank where the hose fits on. Without this screen it will not make foam.
Oct 07, 2007 | Kirby Heritage II Vacuum
Vacuums Logo
185 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
