Question about Mitsubishi HS-U446 VCR
Manual for Mitsubishi VCR HS-U446
I want an operations manual for Mitsubishi VCR HS-U446. A friend gave me one to replace my 16 year-old Sony VCR but no manual came with the Mitsubishi. Any suggestions will be helpful as I can't find any to download on the internet.
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    dont know but will manual for VCR HS-U449 help?most of them have common setup and operations..please let me know..
3 Suggested Answers
nfandres
  • 168 Answers
SOURCE: How do you connect the VCR Mitsubishi HS-U446 to record a TV show?
Usually the standard color coding for those connections are yellow, red and white. Yellow for video, red and white for audio left and right if it is stereo. Also pay attention on the the label of your vcr if it is input or output. You need need to connect it from output of your vcr to the input of your tv set. TV have also the same color coding. By the way the cable you use for this purpose is what we called RCA, which is also color coded. good luck!
Posted on Feb 26, 2007
  • 152 Answers
SOURCE: is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
Posted on May 13, 2009
  • 5 Answers
SOURCE: I have a Mitsubishi HS-U446 vcr and it works fine
There are several companies out there that make replacement remotes, and do not charge a fortune for them I used to have a similar model and got a replacement remote for about 40.00. It may seem like alot, but for that model and the Mitsubishi VCR's in general, I think of it as a wise investment. I used a Co. called Replacement Remotes.com. Ther also is another one called Smart Home remotes.
Posted on Aug 23, 2010
I cant operate my vcr there's a code on it L2 I can't change the channel or record nothing it's theL2
Haveing looked around the web I can only find results for the E2 code for this model.
E2 indicates that the loading motor is locked in the unload direction.
This means that when the tape was in the machine it tried to unload the tape and got stuck. There could be numorous causes for this that would require investigate. Till the fault is cleared the machine will be unoperational.
Nov 30, 2014 | Mitsubishi HS-U446 VCR
My vcr has L2 on it and I can't operate my vcr
L2 is an input (scart probably). Try the "source" button on your remote - it's sometimes got a little circle with a line going out one side. Not up - that's on/off.
I have a Mitsubishi HS-U446 vcr and it works fine but the remote is totally worn out--is it possible to get a new one? Where?
Oct 29, 2009 | Mitsubishi HS-U446 VCR
Is it digital? will I need a converter box?
May 13, 2009 | Mitsubishi HS-U446 VCR
Mitsubishi HS-U445
Check batteries in remote- maybe they are weak/dead. Do the buttons on VCR itself do anything? Unplug VCR for a few minutes, perhaps this will clear the condition. Mitsubishi doesn't show your model, but perhaps this one will be close enough: http://www.mitsubishi-tv.com/j/i/18326/HSU449.html?cid=42
Sep 13, 2007 | Mitsubishi HS-U446 VCR
Feb 26, 2007 | Mitsubishi HS-U446 VCR
Mitsubishi HS-U446 VCR Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
