Question about MTX Car Audio & Video
I need to no how to bridge a mtx thunder TA5601 Amp
    President:
  • 624 Answers
I hesitate to answer this question for fear that you will not like the answer even if it is the truth. I have received a bad rating from a couple of people in the past just because the right answer was not what they wanted to hear.
This is a mono sub-woofer amp, which means that it is already bridged internally. You only have one speaker output in this amp, that means that the amp circuit is bridged inside, it is not split into two channels.
To bridge any output, it requires 2 channels, otherwise there is nothing to bridge.
I have been repairing car amplifiers for over 18 years, and I promise you that there is no way to bridge a single channel amp. Bridging means to convert 2 channels into 1 channel. If all you have is one channel, then there is nothing left to bridge.
I hope this explains it for you, if you have any other questions feel free to post them here and I will answer as soon as possible.
And please do not punish me with a bad rating if you do not like the answer, it is the correct answer, and sometimes the right answer is not always what we want to hear, but it does not make it wrong.
Dave
Posted on Nov 09, 2008
How do I Bridge MTX Thunder 404 400 watts into one channel
The mtx thunder is a 4 channel amp. 4 channels can't be bridged to 1 speaker. You can only use one side of that amp to bridge your speaker. Unfortunately your now only using half your amp.
Nov 25, 2016 | MTX Car Audio & Video
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
How do i bridge x 2
LEFT RIGHT
+(positive) -(negative) +(positive) -(negative)
Connect Left Positive to Right Negative
Connect for both front and back
I found your amps owners manual & quick install sheet @ the link I added.
Oct 20, 2010 | MTX Thunder 404 Car Audio Amplifier
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
I have a mtx thunder 81000d amp i need to know if i can bridge it
Hello frank_sadach,
"Bridging" connects 2 amp channels to one output. The MTX 81000d is a single channel amp so it cannot be bridged.
Hope this helps.
Oct 23, 2009 | Car Audio & Video
Car electronics
Mke Sure The Wires R Tightly Grounded And The Use A Higher Fuse
May 28, 2009 | MTX Audio TC6004 Multi-Channel Amp - 300W...
Picking the right amp.
yes you could go with a 2 channel. You could alwayse bridge it.
Jan 07, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Mtx blue thunder 752 pro
When you bridge amp they some time double in power output into a certain load. If the actual load of your speakers are lower than the required bridged load the out put of the amp will proportionally try to increase again. You have to match your loads to the specs of your amp. Use your manual to see what is required, then use ohms law, for adding resistors in series/parallel to make your speaker load match. For more info please reply.
Nov 21, 2008 | Car Audio & Video
4ohm subwoofer and 2ohm amp
just run str8 pos and negative
Mar 08, 2008 | Car Audio & Video
Mtx 801d
ASSUMING that the amp is OK with a 2ohm load then you "set it up" by the configuration of the speakers you use. Two 4 ohm speakers if parallel will give you a 2 ohm load. However, if you are bridging the ouputs then a single 4 ohm speaker bridged between the two outputs will put a 2 ohm load on each channel. Be very careful if you are bridging the outputs that you know what you are doing. On average, when bridged wrong (too much load) the amp will last about one month before it fries. Get some help if you are bridging. Be sure not sorry.
Jan 14, 2007 | MTX Thunder 801D Car Audio Amplifier
Car Audio & Video Logo
252 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
hoyzee1
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
