Question about SanDisk Sansa Clip MP3 Player
MP3 Player Trouble
Hi, im trying to charge my mp3 player, using a usb cord, and it seems to be charging but when I unplug it from the computer it wont turn on. Also i don;t think I have a reset button to reset it. What should I do?
  • Anonymous Nov 10, 2008
    My Sansa clip mp3 player won't come on either! I was charging it and when it was fully charged i un-plugged it. And then it went out!!! And It's been like 15 minutes and it still won't come on!!
  • 24 Answers
You have to hold your power button up for at least 20-30 seconds and then it should come on. If that doesn't work hold the power button and the home button at the same time for about 10-20 seconds
Posted on Nov 11, 2008
Im trying to charge my mp3 player on my computer but it wont charge
you facing this problem because your mp3 player do not match your computer/charging plug is not working/your computer do not load that thing.
Jan 06, 2013 | HP Portable Mp3 Player With Micro Sd Slot...
Eclipse mp3 player 4g wont charge
Try this. Turn your computer off. Plug in the mp3 via usb port with player in the on postion. Turn the computer back on. You should a large green battery symbol on the screen flashing left to right. Took me about 3 days of finally fiqure it out. Also try different USB ports if you have more than one. Good Luck
May 04, 2012 | Mach Speed Eclipse 180 MP3 Player
Do i need a computer to charge my m.p.3. player
Hi
yes you need a computer to charge your mp3 player if you do not have a charger for your mp3 player
To charge your mp3 with a computer you should swiych it off then connect one end of a USB cord to the mp3 player and the other end to the computer (just like you want to transfer files)
The screen of your mp3 player will light up and you will see an icon or word indicating that the mp3 player is charging.
Jul 04, 2010 | Philips GoGear SA2825/37 MP3 Player
Mp3 player does not seem to fully charge
Try pressing the reset button on the bottom of the unit and restarting your computer then plugging the usb cord. If still not working try charging from an external usb charger that matches the voltage specs for the aquabeat model you have and letting it charge over night.
May 20, 2010 | Speedo 7410061 MP3 Player
How to charge My Mp3Player
Hi giannuandi,
Plug it into a USB port, and it should charge by itself. Use the USB cord Apple supplied for transferring data.
Dec 05, 2009 | Apple iPod shuffle MP3 Player
MP3 Wont charge or upload
u need a new cord for charging.u lost ur receipt so no problem u can buy it any electronic or computer market i hope.
Aug 03, 2009 | SanDisk Sansa Clip MP3 Player
MP3 Player Not Charging!!! (USB)
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje player on
3. turn it off by either holding down the play button, or selecting
"System" from the menu
4. The screen will go black and the battery will begin charging.
Feb 15, 2009 | Coby MP-C7092 (2 GB) MP3 Player
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
How do I charge my MP3 ?
Hello camerorunner,
Most MP3 players can be charged by connecting them to a computer's USB port using the supplied cord. Make sure you are plugging the MP3 player into a USB 2.0 port directly on the computer itself, not on a USB hub. Most USB hubs do not have enough power output to actually charge your player.
The player may also be supplied either a wall adapter or car cord that can be used to charge the unit. However, most manufacturers sell these items as optional accessories.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 17, 2008 | Audio Players & Recorders
Charging problem
Hello lil ronaldo,
It sounds like the internal battery pack may be failing. The rechargeable batteries commonly used in MP3 players last a long time but they do eventually fail and when that happens the battery will fail to properly hold a charge. It may come up to full voltage when you attempt to charge it but will quickly run out of power when removed from the charger. This sounds like what is happening based on your description.
I would recommend contacting Samsung to get battery replacement service. You can call them at 1-800-SAMSUNG (726-7864) or use their online service request tool. If the unit is outside of the original manufacturer's warranty there will probably be a charge for the service.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 15, 2008 | Samsung Yepp YP-P2 Digital Media Player
SanDisk Sansa Clip MP3 Player Logo
80 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
