I have several computers connected to DSL through an EDIMAX router and a modem.
Till yesterday I had an Alcatel modem, and everything was fine.
Today the modem was changed to Aztech 600E, and I can't configure the router properly. I know the protocol is PPPoE, and I have set all parameters correctly (I hope...), but I fail to connect to my ISP.
A single computer connects with no problem through the new modem.
Comments:
Oct 25, 2006
- Sorry, wrong model - I don't have the wireless modem, just a regular one.
Oct 26, 2006
- My computers identify the router. Each gets a separate 192.168.2.* address. Note that nothing has changed except for replacing the modem.
The problem is that the router does not connect to the ISP.
One of the computers (set apart from the others, and not connected to the router) is my "benchmark", allowing me to connect to the Internet not through the router (and write this comment...).
Oct 27, 2006
- OK, it turned out that:
When the technician firt connected the Aztech modem to the DSL, he defined it as a router.
This worked fine for a single computer, but when the Edimax router tried to connect, it failed.
The solution was simply to reset the modem to its defaults.
Now the modem plays the role of a modem, the router plays the role of a router, and all computers connect well.
Does your router automatically set the ip addresses for each computer, or do you have to set them up yourself?
Is the computer that can connect the one that is directly connected to the modem?
if it does and you asked windows to repair the connection it probably is messed up.
check in the router settings to see if your pc's are on the same ip address route (e.g 192.168.x.x), but not all the same last digit; and the subnet masks are all the same (eg 255.255.255.0)
Comments:
Oct 26, 2006
- Are you able to view your ISP's WAN IP and SUBNET MASK, PRIMARY DNS SERVER AND SECONDARY DNS SERVER, in internet settings in your router, as sometimes you have to telephone them and manually input the settings as i had to do with Onetel Telecom, but with TalkTalk I don't have to it's automatically recognised by my wireless router.
hi, i want to ask why sometimes i cant connect to the internet using my dlink G router dir-300 but...
(More)
hi, i want to ask why sometimes i cant connect to the internet using my dlink G router dir-300 but when i plug my dsl cable directly to the laptop, i can go online
I am a user from Philippines. My ISP is ComClark Cable, which uses L2TP to set up internet...
(More)
I am a user from Philippines. My ISP is ComClark Cable, which uses L2TP to set up internet connection. Does your router support this ISP or not?
this is the wireless network connection that i use, Intel(R) PROSet/wireless 3945ABG network...
(More)
this is the wireless network connection that i use, Intel(R) PROSet/wireless 3945ABG network connection. i can detect my office wireless network but cant connect to it. May i know what should i do for it to make it connected? any setting or i need to install others driver in my laktop? thank you.
I have3 dishes connected to my Dbox500s. Dream and Australianetwork no probs! Multichoice on 68.5...
(More)
I have3 dishes connected to my Dbox500s. Dream and Australianetwork no probs! Multichoice on 68.5 sometimes takes 20 mins to activate other times maybe 20 to 60 seconds After activation it runs for max 30 minutes then freezes from 20 seconds to 20 minutes with only 2 or 3 mins active between freezing. Imagine trying to watch any sport !! My DCC on my XP shows all green connections. PC 192.168.2.101 Dbox 2.100 Router 2.1 SNR always +85 AGC +93 BER 0 Any clues on how to get rid of this frustrating proplem ?? Regards Janjoysdad
