Question about LG WM2277H Front Load Washer
Leaks water is leaking from what appears to be the front left corner during its cycle. Amounts very from a little to a lot.
  • skelly782 Nov 09, 2008
    water leaking during wash cycle
  • hduffy Nov 15, 2008
    Sporadic leaking, appears to be left front. LG tech support says to frequently drain the compartment for the filter on the lower left but this doesn't make sense. Entire system should be water tight. Help
The only time I've noticed a puddle on the floor was when I used too much HE detergent. No matter how big the load is, I only fill the cup to the very first line of the cup that comes with the detergent. It's no where near the max level on the detergent reservoir for the machine. Try using less detergent (way less) and see if that fixes the problem. My clothes still get squeaky clean!
Posted on Nov 09, 2008
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
Aug 06, 2014 | Samsung Front Load Washer Control Board...
Maytag washer lat8600
That model doesnt come up on Matags web site?
Nov 25, 2013 | Whirlpool Washing Machines
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Leaking from left corner GLD2250rd Frigidaire dishwasher
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Front door leaking during washing cycle
There are only two ways that water can leak out this way. it can be either the door seal or the door lock mech has become misaligned, causing a slight gap that is letting the water escape through.
I recommend inspecting the door lock mech for its integrity. make sure it is aligned correctly to specs. replace this mechanism if found to be faulty or misaligned. i would also inspect the seal for tiny ruptures as well. the slightest rupture or hole can allow small amounts of water to excape.
Inspect these areas thouroughly.
May 31, 2009 | Frigidaire Washing Machines
Kenmore Washer Leak
Check the back of the tub as the water is coming in. Sometimes the water inlet gets knocked out of line if the machine shakes a lot or gets moved.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Leaking from the front top of machine immediately when cycle begins...
Not sure if this is the same problem but my old WD800 used to spew water out of the top left corner where the detergent tray is. This occurred at one point in the cycle. It was cured by turning down the incoming water pressure on the external tap under the kitchen sink (in this particular case, the cold water)
Jan 28, 2007 | Malber WD1000 Front Load Washer/Dryer
LG WM2277H Front Load Washer Logo
304 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
