Question about Cozy (W352E) Heater
The heater will not ignite properly
Info: Cozy Wall heater furnace
One side heater
Problem:
The thermostat is left at 60 degrees to keep the heater off. When the thermostat is set up to 75, the heater goes on for two seconds and shuts off.
If the heater is left alone, it continues to go on for two seconds and shuts off, over and over, or it may not go on at all. This lasts for 20mins to an hour. Eventually, the heater goes on and stays on.
If the heater door is slapped a few times, the heater will go on and stay on.
--The heater will not shut off
Once the heater gets going, it won't shut off. The thermostat to be turned back down below 70 in order for the burner to shut off.
Note:
There heater's Pilot generator was replaced last February 2007, and the heater appeared to work OK for awhile: it went on and stayed on when the thermostat was set above room temperature. However, the ignition problem soon returned (the heater had to be banged for the burned to stay lit), and it appears to be more pronounced this fall
Also:
This need to be answered too
The pilot flame goes out for some reason. What is the problem?
  • 306 Answers
How old is the thermostat? Also there a limit switches at different points on that unit. If you have a volt ohm meter find the round disc like safety's and ohm them out. Take the wires off the disc before testing them. You should have a continuity should be closed they only open if unit gets too hot. Say something like 180 degree's.
A fast way to check out the thermostat is take a small diameter wire take the cover off the t-stat and jump across the R and the W on the t-stat. If the furnace comes on then t-stat bad. Let me know if this is helpfull. Ken
Posted on Nov 26, 2008
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
Cozy wall furnace (propane) does not respond to thermostat. The pilot is lit. Furnace is 3 yrs. old and rarely works. The wire to thermostat is 20 feet.
Try jumping the two thermostat wires together to see if the heater starts. If so, replace your thermostat. If not, jump the two terminals where the thermosta twires attach to the furnace. If it starts, you have a bad thermostat wire or connection.
Jan 30, 2010 | Cozy (W352E) Heater
What is easy way to replace the thermostate in
Hi, that thermostat should be a wall mount. This heater has only 2 wires and any "Heat only", "millivolt" thermostat will work. Remove the old T-Stat and mount the new one on the wall, only 2 wires and less than a volt so no shock danger, doesn't even matter which wire goes where. Good luck and comment back if you need any help.
Jan 09, 2010 | Cozy Heating & Cooling
I have a cozy gas furnace that only comes on when you bump it.
Hi loose connection in the heater or sticking fan or gas valve
Jan 09, 2010 | Cozy (W352E) Heater
The heater will not ignite properly and the heater will not shut off
Judging by your pics (helpful, by the way) you have a high limit wired into your thermostat wire. Try disconnecting that wire nut connection in front of your valve and hooking the thermostat straight to the top and bottom posts on the valve (eliminating the high limit). If it runs fine, either the connection was poor or your high limit wire is pinched.
Feb 28, 2008 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
255 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
