WHEN I SWITCH MY LAPTOP ON IT WONT STAR UP IT JUST SAYS WINDOW FAILED TO START
  • lord-douglas Nov 09, 2008
    thankx i hope it works
  • 144 Answers
You will have to reinstall windows with the CD that came alongwith your laptop/ simply carry to the dealer from where you purchased this.
Posted on Nov 09, 2008
Tried to jump start my dead battery on my 950-T it wont say running and the engine, fuel, and oil light are flashing when it runs then it just dies is the battery ruined?
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
http://www.starbikeforums.com/forums/49-v-star/5524-vstar-950-starter-motor-failure.html
VStar charging problem
YAMAHA XVS950A Owner Manual
OEM parts for Yamaha
2010 Yamaha STAR 950 TOURER Motorcycle Service Manual Download Manuals...
Apr 22, 2014 | 2010 Yamaha V Star 950
My 2009 950 v star will not come on . no lights horn or nothing
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.starbikeforums.com/forums/49-v-star/9371-good-battery-no-power-1100-v-star.html
Re My Yahama Star 1100 wont start Road Star Forum Yamaha Road Star
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
Yamaha STAR XVS950 Owner Manual
Apr 02, 2014 | 2009 Yamaha V Star 950 Tourer
99 buick century window wont go up, Thought it was just switch, replaced switch. still wont work.
The window may be binding in the track or the track may be loose. Another possibility is that the motor may have failed.
Oct 28, 2013 | Computers & Internet
I have a 2002 Yamaha V-Star, I just purchased a new sealed battery, and it starts the bike fine, but as soon as I shut her off, it wont start back up !
Have you done all the regular stuff? There are a number of interlock safeties on this bike. To start, key on of course, side stand up or in neutral, if in gear and clutch is engaged, it will not start, if the kill switch is in the off position, it will not start. Said differently, you must have the key in the on position, side stand retracted, transmission in neutral, clutch pulled in, kill switch in run position. Still will not start, check the start solenoid for proper operation. If that works ... suspect the starter motor.
Mar 01, 2013 | 2002 Yamaha V Star 1100 Custom
1997 Yamaha Royal Star Tour Deluxe quits running while riding
Hi, Ed4benefits and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
6. Failed ignition coil, stator, magneto, ignition/electronic module.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Air/fuel mixture screw improperly adjusted.
11. Accelerator pump damaged or not working.
12. Water or dirt in the fuel system, carburetor or filter.
13. Restricted, blocked or kinked fuel line.
14. Fuel tank empty.
15. The gas cap is not venting properly or fuel tank venting system blocked.
16. A failed fuel pump, pressure regulator and or fuel injectors.
17. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
18. Needle and seat stuck closed in the float bowl.
19. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1996 Yamaha Royal Star 1300 won stay running
Yamaha XVZ13TFL Service Manual
Yamaha XVZ13LT Owner Manual
Yamaha XVZ 1300 Royal Star Tour Classic 1997
Yamaha Royal Star
May 24, 2017 | 1997 Yamaha Royal Star XVZ 1300 A
1981 Yamaha XS650 won't start just clicks
Hi, Damiclem before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
http://www.starbikeforums.com/forums/49-v-star/2588-650-custom-wont-start-just-clicks.html
What to do When Your Motorcycle Won Start
Yamaha XS650SE Shop Manual
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
Jul 11, 2011 | Yamaha XS 650 A Motorcycles
Power windows don't work
This could be several things: lets start with the basics, check for a blown fuse or failed wire (this would especially hold true if they failed at the same time. Could also be control switch (does the passenger switch operate its window?) if this is the case the master switch has either failed or failed wiring. Lastly there are the window motors, these too may have failed. If it sounds as if the windows are trying to operate but unable to move; the mechanics of the windows may be coroded, overly dirty or in need of lubrication (WD40)
I hope this may have helped,
Tom
Sep 23, 2009 | 1992 Dodge Dakota
The car when you park it wont start
Loose wire on ignition switch .the security light is grounded .
Jul 10, 2009 | 1991 Oldsmobile 88
1995 Izuzu Rodeo passanger window wont go down
Sounds like failed window switch.Local repair shop should be able to help.
Mar 31, 2009 | 1994 Isuzu Rodeo
Computers & Internet Logo
David Payne
David Payne
