Question about Maytag Washing Machines
My maytag performa top load washer lid have a broken hinges. where do i go to get parts?
    Sergeant:
    Champion:
  • 324 Answers
Www.repairclinic.com
Posted on Nov 09, 2008
I fill machine with water but have top slam lid down and put some thing on top of the lid for laundry to start. now it just won't start. what do i do?
lid safety switch not engaging,had the same problem with my atlantis.turns out the plastic hinge pin bushings in the body of the washer where the lid is hinged. breaks apart.allowing the lid to come out of alignment. easy fix and the bushing is only about 2 bucks each at an appliance parts store...
Dec 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
How do i unlock a maytag neptune tl?
Disconnect the machine from power source then insert a plastic putty knife or similar tool in line with the lid seam and push in to release catches on the left and right side. The top cover can then be hinged up.
Once the top cover is raised, remove each of the 1/4" hex-head screw attaching each lid lock to the top cover.
Release the lid locks from the lid then reinstall them back into the top cover. Take the opportunity to visually check the lid locks and the harnesses for any obvious sign of degradation such corrosion and broken wires.
Sep 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag performa top loading washer will not spin or drain, what could be the problem and how do i fix it?
HELLO THERE
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Aug 20, 2010 | Maytag Performa PAV2200
Maytag performa top load will not work
more than likely it is your lid switch asm. I is the switch in the back edge of the lid?
Mar 07, 2009 | Maytag LAT2300 Top Load Washer
How to replace hinge lid pins
At the back of the washer just below the control panel there are two 8mm metal screws remove them there are 2 clips they will alow you to lift the top up in the front of the washer the top cover has 2 spring type holders if you slide a small screw driver in the opening and push gentle on the spring clips they will release and you can lift the top off the washer there is a screw on each hinge this will remove the old hinge then replace with new ones hope this will help
Jan 24, 2009 | Maytag PAV2300 Top Load Washer
Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Apr 28, 2008 | Maytag Performa PAV2200
To replace part #1477, female hinge part for lid
Take a plastic putty knife and insert it under head. On each side.there is a push tab now where the 2 screws used to be push real hard in and the head will pop up
Dec 02, 2007 | Maytag PAV2300 Top Load Washer
Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Jun 12, 2007 | Maytag Performa PAV2200
Washing Machines Logo
99 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
