Question about Jenn-Air PRG3010 (NP) Gas Kitchen Range
Trouble reinstalling door for Jenn-Air PRG3010
I cannot get the latches to re-engage when trying to reinstall the front oven door. Any tips?
There is a very small clip at the bottom of the door hinge which in essence locks the door open if it is in place. You need to make sure that clip is in an "open" position to accept the door.
Posted on Nov 13, 2008
How do I Put the door back on
the hinges have to be partly open like you were letting the oven cool then just slide the door back down on the hinges .
Nov 29, 2014 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Jenn Air dishwasher door won't close
i had the exact same issue. it's a broken latch mechanism, and is a fairly common problem.
i bought the part at my local repair shop for $45 (you can find it online for $30). it literally took 10 minutes.
you need to right size bit to remove the 10 bolts on the interior of the door. once you have those out, the latch slides right out of the top. there are 2 electrical connectors (careful - you can get a shock. disconnect the 2 connectors, reconnect to the new one, and zip your 10 bolts back in. super easy
Aug 18, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven door locked - jenn air
My Jenn-Air double oven locked after a clean cycle. My model (JJW8630) has a series of slots cut in the top of the door. Take a piece of stiff wire, coat hanger, and bend a right angle about 1/2 inch at the end, feed the wire into the 3rd or 4th slot from the center on the right hand side. Turn the wire so that the bent piece is on the top and push the wire so it engages the lever which latches the door shut, it is spring loaded and moves easily.
Once the door was opened, I removed the temperature sensor, held by 2 screws, from the top of the oven and eased the wire out to get to the connector. The faulty sensor was reading 4.2 k, at room temperature it should be just over 1k, while waiting for a new sensor to arrive I stuck in a 1k resistor, ex Radio Shack, so the fan stops running and the door latch can be retracted by closing the oven door, or press the switch on the top right of the door opening.
My replacement part was ordered on line for less than 1/2 the official quoted price.
Hope this helps.
Jul 18, 2008 | Jenn-Air JJW8430D Electric Double Oven
Oven door
it depends on the type of hinges, you would most likely have to push the hinges down and latch it with the small hook on both sides then put your door back on , push the door fully open ond unhook the small hooks.
Feb 18, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air single electric wall oven #JJW9530DDS
try to open the door see if the door latch is extended if it is locate the light switch on the oven cavity and hold it in then hit start then cancel or stop the latch rod should go back
Dec 27, 2007 | Jenn-Air JJW9530C Expressions Collection...
JennAir PRG3010NP convection oven noisey
hi thanks for the question it sounds like the blower for the convection has a bad bearing your probably looking at 100.00 $ for the repair thanks the appliance doc
Dec 22, 2006 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Jenn-Air PRG3010 (NP) Gas Kitchen Range Logo
236 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
