Question about KitchenAid Dishwashers
How do I remove the bottom spray arms of my Kitchen Aid Dishwasher (Model is kuds01ILBS3) to clean the screen and what is inside. Arshad
  • awp4 Nov 09, 2008
    Ok. How do I remove the last screw that is under the arm.
    I can provide a picture, but do not know how to add to the comment.
    Arshad.
  • awp4 Nov 10, 2008
    Thanks. That worked. Best 10.00 bucks I ever spent.
    Arshad.
  • KitchenAid Master
  • 19,396 Answers
I report:
To remove the plastic water tubing that goes up the back and to the center and top/roof sprayers:
1) Remove rack stops for top rack and remove complete rack and sprayer arm assembly.
2) Release metal tabs that snap over tabs on plastic tubing on the roof of the dishwasher.
3) Release metal tabs that snap over tabs on plastic tubing on the back of dishwasher about half way up the back.
4) You maybe able to lean complete unit forward and disengage from lasttab on supply tube at bottom. If it doesn't have enough room to comeout then remove bottom spray arm and turn supply tub under lower sprayarm counterclockwise about a quarter turn and it will lift up and out.
From kitchenaid
See also the diagrams:
UPPER WASH ARM:
LOWER WASH ARM:
TUBE ASSEMBLY:
Posted on Nov 09, 2008
    Genius:
  • 1,689 Answers
Use a smal socket wrench, if you have an interchangable spark-plug set, you may change the socket to one that will fit the screw. this will give you flexibility to remove the srew and be able to remove and put it back from a tight space.
    President:
  • 1,952 Answers
Most likely there is a foreign object inside the pump intake which could cause a damage to the motor and/or impeller.
Remove the lower spray arm and the filter.
Remove the screw holding the impeller cover (#10 on the motor & pump break down diagram). Remove the cover and check for any foreign objects.
  • mohammed marika thambi
    mohammed marika thambi Nov 09, 2008
    Over time,
    the small holes in the spray arm(s) of your dishwasher may become
    clogged with bits of paper, toothpicks, glass, etc. Your dishwasher
    will do a better job of cleaning your dishes if you take a moment to
    clean out these small holes, from time to time.
    CLICK THIS LINK. http://www.repairclinic.com/0003.asp
    Genius:
  • 1,550 Answers
  • Remove lower spray arm by unscrewing plastic screw, it should only be hand tight.
  • In order to remove the strainer cover, you will need to remove the plastic tube that takes water to the middle and top spray arms. Unclip this tube from the top and middle clips and then work it out of the strainer assembly tube. Now you should be able to remove the tube at the bottom of the dishwasher by unscrewing it 1/4 turn.
  • Remove the strainer cover by unscrewing the 4 Torqs screws.
  • You will now see two smaller torqs screws that hold the hold the Chopper Assembly cover down. Take these two screws out and remove the two piece cover.
  • Sponge out the water, turn water off to dishwasher, and observe the rotation of the motor.
  • Put everything back together and make sure it works!
    Sergeant:
    Novelist:
  • 196 Answers
4) You maybe able to lean complete unit forward and disengage from last tab on supply tube at bottom. If it doesn't have enough room to come out then remove bottom spray arm and turn supply tub under lower spray arm counterclockwise about a quarter turn and it will lift up and out.
  • mmechanics Nov 09, 2008
    http://kitchen.manualsonline.com/manuals...
    check out this link
    insert the proper model number of your  machine.and get the manual here and there it is given all the instructions with pictures on how to remove it carefully.
    thanks.
    Genius:
  • 3,422 Answers
HI,
To access the bottom spray arm, remove the bottom dish rack. Reach in and spin the spray arms. They should spin freely. Lift up the spray arm from the end. There should some play in the arm allowing you to wobble it up and down. Inspect the seams of the arms for splits. If water sprays out of a seam, the dishes will not receive an adequate spray for proper cleansing and the force of the water directed at the door may cause leakage.
The lower spray arm may also have a spray tower. If it does, pull up the center part of it as far as it will extend and let it drop. It should lift and drop smoothly. You can also unscrew the tower by hand to inspect the interior for foreign objects that might clog it.
Remove the upper glass rack as necessary to access the upper spray arm. Repeat the steps above for the lower spray arm. The upper arm may not have as much wobble as the lower arm.
The water source for upper spray arm on some dishwashers may be through a tube which mates with the spray arm when the rack is pushed all the way back. Make sure that the rack is properly aligned with the water supply tube.
If necessary, the spray arm can be removed for cleaning or replacement. Unscrew the spray tower (if any) by hand and remove the bolt (if any) in the center of the spray arm. Otherwise lift and rock the spray arm until it comes off. Keep any washers in the same order as they are removed. To clean, soak it in warm water and rinse with a vigorous spray.
    Sergeant:
    Champion:
  • 200 Answers
Hi
Some dishwashers have just one spray arm at the bottom in the tub, others have a second spray arm under or over the glass rack. Some dishwashers also have a spray tower that rises up out of the lower spray arm to concentrate an additional blast of water.
thank you
  • Thafa Nov 09, 2008
    Hi
    Follow the steps what we prefer..U can remove the spray arms of my Kitchen Aid Dishwasher
    thank you
The rinse aid dispenser is not adding any rinse aid. how do I unclog it so my drinking glasses don't come out feeling like they have sand all over them.
Good Morning friend, thank you for your post!
I see that you are having an issue with your rinse aid dispenser not adding rinse aid into your Frigidaire dishwasher. You may need to run hot water into your dispenser to help clear out any dirt or clogs within your dispenser. If that does not help I would recommend making sure the water temperature inside your dishwasher is at 120 degrees. If the water is not at the correct temperature it will not allow proper dispensing of the rinse aid. You may also want to check the filter at the bottom of your dishwasher to assure that it has been cleaned out and is not distributing dirt or debris inside of your dishwasher. I would also recommend checking the spray arms to make sure they are not dirty and spray water evenly. You can clean them out using a pipe cleaner. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Frigidaire Dishwashers
Dishwasher-bottom arm not spraying
The spray arms can usually be removed by unscrewing (clockwise or counter clockwise depending on brand and model), or squeezing a retainer to release the arm. Before removing the spray arm, place the spray arms (all) in a specific position and activate the dishwasher for a few seconds with wash action. Then examine the position of the spray arms to determine if there was movement from the spray arms. If not, then the spray arm(s) are probably clogged and restricting water flow (which makes them turn). Make certain that you are positioning the plates, glasses, etc. in the dishwasher so that they have access to the water. If still no luck, contact an appliance service company.
Feb 20, 2010 | Jade RJDW2470A Free-standing Dishwasher
My Kitchen Aid KUDI01FLBL3 is not cleaning my
Most likely there is debris at the pump impeller. This model has a problem with debris and grease accumulation at the pump inlet. I have no idea how it gets past the screen but it does. Remove the transfer tube on the back wall, the lower sprayer, and screen assembly. Clean out the debris and reverse installation.
Sep 16, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Top rack of Kitchen Aid not clean
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Sep 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Jun 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
Dishwasher does not clean items on top shelf.
Check the upper spray arm holes for debris that may be plugging up the spray arm. If clean remove the lower spray arm and filter screen and clean out any debris in the sump.
Feb 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Dishwasher does not clean properly
sewnice, you might have to dig a little deeper to correct the problem. As long as you can spin the spray arm with your hand and it's not split it should be ok. Your chopper screen might be plugged. You will have to remove the lower spray arm and filter cover. These are torq screws. The accumulator assy. turns to the right to unlock and will lift off. It will take some pressue to snap it off the rear fill tube. Now you will be looking down at the cover that protects the chopper and screen. There is one torq screw holding it down. Remove the screw and lift it off. See if the screen is clogged. If it is, it will prevent the pump from sending water to the upper spray arm in force. Catriver..post back
Feb 24, 2007 | Whirlpool 24 in. GU2600XTP Built-in...
Dishwashers Logo
600 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
