Question about Samtron 76df 17" CRT Monitor
Changing monitors I have a Samstron 76E 17ins CRT and decided to change it to a LCD monitor. However I did not get a wire with the LCD monitor and I don't know how to take the wire out of the old (samtron 76e) monitor. Does the wire not come out of the monitor or do I have to screww the back off? Please help Thank you Bal
    President:
  • 2,961 Answers
If the video cable will come out of the monitor the connector will look like the one that is connected to the back of your pc on the other end with 2 long screws. If its simply a wire straight in you cant remove it. If you mean the power cable, you will need the same 3 pin connector as a kettle has, or it will have a special connector which normally has a voltage regulator built in the plug
Posted on Oct 25, 2006
The issue is that I had an XP machine and I bought a brand new HP deskktop Windows 7 and as soon as I turned it on I got a message on my Kogi that I should change the settings to 1280 X1024. Since I did...
To change the screen resolution, click on Start - Control Panel - Display - Settings tab and the adjust the screen resolution slider to 1280X1024 click Apply.
Feb 03, 2011 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
I get a box that says ''Out of Frequency Range''
Is it an LCD or CRT monitor? Sounds like a cable to me. If it's an LCD, then just change out the cable. But if it is a CRT, then it will be more difficult because it is wired directly into the back of that type of monitor.
Jul 08, 2009 | Computers & Internet
Conver the signal of old CRT to VGA signal.
we use the old CRT monitor made by motorola with TTL video signal and different vertical &horizontal frequency signals than monitor with vga signal.at now we can not replace crt with lcd .is there any interface to convert this crt signal to vga monitor signal for replacing the crt with lcd or vga monitor ,beacause this crt is discontinued and the quality of video is weak.if you needs the crt specification i will post it for you.thanks.
Jan 30, 2009 | Computers & Internet
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Acerview 76e
hi shouldibuyit
resolution 640x480 70Hz
800x600 70Hz
best 1152x 870 75HZ
Max 1280x 1024 60hz
these machines dont usually last long if left running at max refresh rate of 85Hz for long periods
Oct 27, 2008 | AcerView 76E Monitor
Change power output from motherboard
Windows will automatically install your desktop monitor using generic drivers. But if it doesn't, go to safemode by pressing F8 before it goes to windows. Change your settings from there. Also, normally, CRT monitors can take more than LCD monitors.
Sep 08, 2008 | ASUS V8440 (128 MB) Graphic Card
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Two horizontal lines
Please verify the same monitor with other computer, Else try changing the display card if you have a CRT monitor. If you have lcd try to workit on other PC, If you get the same result from other computer ; you need to change LCD of your monitor.
Mar 05, 2008 | Dell P793 17" CRT Monitor
My samstron monitor goes dead after 5 min
The problem is not yet serious, no parts yet to replace. That is a result of a "cold solder" of the parts inside. Open the case, clean it with a soft brush and look for these cold solders on the circuit board... resolder what you find and check every pin...
see picture, the rings are somewhat the start of disconnected pin from being soldered.
After that test the monitor..... That's it... Fixya me okay...
Rate us Best for your own future reputations.
Feb 10, 2008 | SAMTRON 55V 15" CRT Monitor
Lcd screen black sometimes
try to change the LCD power settings ... this is a hardware assue ... but i think it will change when u change this settings
Jul 15, 2007 | Compaq (253219-002) Motherboard
Samtron 76df 17" CRT Monitor Logo
77 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
