Yamaha DSP-A1 Receiver Logo
Jose Willington Posted on Oct 25, 2006
DSP-A1 Power Off
My DSP-A1 is powered off when I put the volume up (between 1/4 and 1/2) after many years, having the same configuration, including wires, speakers and units attached. Configuration: B&W Front, effect and center speakers (large). Niles as rear speakers. I have attached: DVD Audio unit, CDRW recorder, LD/DVD Player, MD Player, Phono turnover, VCR, TIVO, DIRECTV. All wires are MONSTER CABLES.
A
Anonymous
The A1 has an internal self diagnostic program which you can go through to find the fault. You can access the diagnostic program by simultaneously pushing some buttons on the front panel. The Yamaha service manual for the A1 tells how to do it and what the diagnostic codes mean. You can get a copy of the service manual on the web from several suppliers for a small fee.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 18, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
608
Points
I am no expert but i had simmilar problems and it turned out that some capacitors needed replacing
Anonymous
Level 1:
  • Posted on Sep 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
608
Points
All you have to do, check all your speaker terminal and tighten it
Problem with volume motor
https://www.hifiengine.com/manual_library/yamaha/dsp-a1.shtml?_e_pi_=7%2CPAGE_ID10%2C1711428461
No volume
try reflashing firmware ,or install some third party dsp or some audio test tool where you would see your sound card
Can i connect a powered subwoofer to center channel pre-out connection inYamaha DSP-A1
YAMAHA DSP A1 WONT SWITCH ON
Popped power supply hi sorry if you can't get it on trying to do a diagnostic won't matter if you can open the back check where the power is going into you will c a power supply board a cap has carrots on it check if any of them is popped up
1helpful
Have Problem With Yamaha DSP A 1. power does not come on...after repeatedly pressing the on switch it comes on and then works fine ..most of the PSU cold solder prob solved...what could be the possible...
Either the power switch is shorting out, or you could have a faulty or somewhat faulty resistor or capacitor on the power board. You can test them with an anlalog meter. Each component has an imprinted number on it to determine it voltage and ohm rating. That number should match the number on your tester.
Some units also have relays in them. The little square plastic boxes. You can test these with an ohmmeter but you would likely have to pull the circuit board to test the relay from the solder joints on the bottom.
3answers
Yamaha DSP-A1 sound drops at startup
In the manual it says switch off leave for 30 seconds and switch back on .
2answers
Yamaha dsp a1
to get to the diagnostic menu on the machine press power button set menu + button and next key all at the same time which will take you to the diagnostic menu
Please Help about a Yamaha DSP-A1
1helpful
2answers
Av amplifier
The display problem is because the solderings on the back of the display are broken. To fix it you have to open the amp and redo the solderings (there are about 50 or 60 of them). There is a Youtube video that shows how to do it. I have fixed this on my DSP-A1.
I also have the problem with the motorized volume control. I have tried cleaning it, and it works for a few days, then it's stuck again. I guess I will have to replace it to have it fixed permanently. The part number is VZ621400, a new one costs about 40$.
Volume level dropping unexpectadly
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
