Question about Computar (TG4Z2813FCS) Lens
No spark have 1991 dodge dystany have no spark on no. 4 cycliner pulled wire from coil no spark have replaced the computor engtne is a 3.3
  • 85 Answers
Replace the coil see what happens. good luck.
Posted on Nov 09, 2008
Van backfiring when driving at low speed
For the 3.3L:
Firing Order:
1-2-3-4-5-6
Cylinders:
(back of vehicle)
1--------3--------5
2--------4--------6
(front of vehicle)
Ignition Coil:
(back)
6---3
4---1
2---5
Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
Jul 13, 2010 | 1991 Dodge Caravan
96 dodge caravan wont fire on cylinder 1 or 4. coil pack is good. fuses are good. just no spark
check pulse on coil pack conector with noid light ,remember cylinders 1&4 fire at the same time. check pulse while cranking. most likely you have a bad computor or a broken wire
Feb 25, 2010 | 1996 Dodge Caravan
I have a 1991 Dodge Ram pick-up and I cannot get spark. Can you help?
ck for the pick up coil working.unplug pick up coil remove wire from ignition coil to dist lay coil wire still connected to coil about 1/2 inch from ground turn key on take a jumper wire and jump the wires on the engine harness side of the connector if it has a spark replace the pick up coil in the distributor
Jan 01, 2010 | 1999 Dodge Ram
Engine cranks but will not fire.
check to see if you are getting a spark from the plugs. Just pull the plug and connect it back to plug wire. Then with gloves ground of that plug at the threds. Have someone try to start it only allowing 3-4 repatisions, and see if you have a spark. If you dont have a spark, then it would be eaither be the sparkplugs, plug wiers, or your coil is bad.
May 19, 2009 | 1991 Dodge Dynasty
1991 Dodge 318 no spark
Yes,an ohmeter across the two power leads(pimary) should yeild a fairly low resistance I'm not sure on the specs but it is just a winding so maybe 10 ohms,then test the secodary winding with one lead to either power lead and one lead to the high voltage post(the coil wire connection),should read about 10k ohms,you can go to autozone.com and register and they have a repair guide that should have the test specs.
May 17, 2009 | 1991 Dodge D150
86 dodge 250 v8-318 no fire at spark plug, will not start
did you change the main coil and coil wire?if so then check the ing resistor and then the computor box
Mar 20, 2009 | 1989 Dodge D150
Dead cylinders 2003 sebring
it sounds like you may have the wires on the wrong coil. It should be #1 on the #4 coil, and the #3 wire on the #2 coil. you probably have them backwards so 1 and 3 are firing on the exhaust stroke.
the firing order is 1-3-4-2.
they should be hooked like this.
Jan 23, 2009 | 2003 Chrysler Sebring
Starting
You need four things to get combustion in the engine - proper timing, air, spark, and fuel. First, check for an engine error code. If there is none, check for spark by pulling out a spark plug wire and place the lead near a ground. If you have a spark while the engine turns over, then that's one component down. If you don't, check the coil for a spark. If you don't get it there, replace the coil. Similarly, check the fuel filter and air filter. If nothing's turning up, then look at the timing belt.
Jul 11, 2008 | 1991 Dodge Stealth
Computar (TG4Z2813FCS) Lens Logo
20 people viewed this question
Top Computar Cameras Experts
Are you a Computar Camera Expert? Answer questions, earn points and help others
