Question about Refrigerators
Hotpoint 6961 fridge,replace door hinges - Refrigerators
3 Suggested Answers
  • 29 Answers
SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
SOURCE: The top hinge of my neff integrated fridge freezer has broken.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
Posted on Jun 12, 2010
Hi, I have a hotpoint fridge/freezer future rf 175wp and want to change the doors from right hand to left hand hanging. Do I need to get new hinges? Thanks Dave Horn
Dave,
You should not need new hinges. As long as you have screw holes on both sides you re-use the same hinges, just flip the middle one over. The bottom hinge point, you will need to move the post from one side to the other. Hope this helps!
May 07, 2015 | Hotpoint Refrigerators
Fridge light not working
door light switch Need full model # for better idea .
but normal switch should be at bottom of door or at hing side of ref
some model have at top it may be broke off and thats why you don't see it send us a full model number we will find for you
Feb 28, 2015 | Hotpoint Refrigerators
Hotpoint fridge freezer door not shutting
Adjust the feet at the bottom or the hinges if that doesn't work check your gasket and the white plastic washer on the hinge
Oct 23, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
THE REFRIGERATOR FREEZER DOOR STAYS SHUT BUT THERE IS NO SUCTION AND I AM GETTING ICE CRYSTALS INSIDE THE FREEZER. WHAT COULD THE PROBLEM BE?
there is some thing wrong whit your door gasket, check your door gasket all around and see if is seal properly, if is broken there is places than custom make fridge gaskets. if by any chance you tuck your doors a part, may be than you dint properly adjust the door or you are missing a shim if so.
use some coins to adjust the hinges. buy placing in between the fridge body and the hinge.
place a piece of paper on the fridge and close the door it shut hold the paper all the way around the door.
Good luck :)
Apr 06, 2009 | Hotpoint RLA50 Refrigerator
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Freezer
there are what are called door "cams" on the bottom of the doors. One piece is on the bottom of the door and the other one is on the hinge. Both pieces need to be replaced and it is possible both your doors may need them. The parts come as a hinge assembly. That means you need to replaced the hinges on the bottom and they should come with the piece that goes on the bottom of the door also. You may also have a blocked defrost drain. There is a hole in the center rear, under the evap plate there where you see the dripping. that may need some air pressure blown through it to clear it. remeber, ever time the unit defrost, you will get that water.
Aug 11, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
May 02, 2008 | Refrigerators
Refrigerators Logo
180 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
