Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
Loading Myfi Suddenly having problem with my MYfi - sometimes it works -then goes to the loading screen for the channel.   Have tried hooking up another antenna and it does the same thing.  Sometimes when I power it off - then power it on again it works for a short time.   Don't know if the base is the problem.
  • 94 Answers
Reset your MyFi by removing the battery cover and inserting a paper clip into the hole marked “RESET”at the upper left-hand corner of the case.
Posted on Nov 09, 2008
    Sergeant:
    Novelist:
  • 196 Answers
Its the problem in the power supply cable.check it out.some where loose.
  • 5 more comments
  • mmechanics Nov 09, 2008
    Signal reception guidelines
    Your MyFi’s antenna should have an unobstructed view
    of the XM satellites in the southern sky. In large cities,
    XM also has a network of ground repeaters to help
    increase the signal coverage.
    Other Things You Should Know
    Care
    You should be able to take your MyFi along with you
    during most of your daily activities. Still, you should
    remember:
    • Your MyFi is not waterproof. Avoid splashing it with
    liquids and never submerge it.
    • Take your MyFi with you when you leave your vehicle,
    especially on a hot day. Not only can you continue to
    enjoy XM programming, but you’ll also prolong the
    life of your MyFi’s case, display, and battery.
    • If your MyFi gets dirty, wipe the case with a soft cloth
    lightly moistened with water, then wipe dry with
    another cloth. Avoid chemicals such as paint thinner,
    alcohol, or abrasive cleansers.
    Important battery information—please read
    Your MyFi’s battery should be charged before you use
    the radio. The amount of charge is indicated by the
    battery level meter in your MyFi’s display. When you’re
    charging the battery, you will see . When the battery
    is exhausted, you will see .
    When you use your MyFi for the first time, charge the
    battery until the meter indicates it’s fully charged .
    Then use your MyFi until the battery is exhausted. This
    charge/discharge cycle calibrates the battery level meter
    so that it accurately reports the state of the battery.
    Your battery performs best when used and charged in
    an ambient temperature of between 50°F to 90°F (10°C
    to 32°C). Do not leave your MyFi inside a hot vehicle or
    in direct sunlight.
    Batteries gradually wear down and require longer
    charging times. When a battery no longer holds its
    charge, you should purchase a new battery. Always
    use authorized batteries and power adaptors.
    Replacement batteries and power adaptors can
    be ordered online at www.xmradio.com.
    To prevent injuring yourself or damaging your MyFi, do
    not disassemble, crush, or puncture the battery. Never
    allow metal to touch the battery terminals
    Your MyFi’s rechargeable battery should be
    disposed of properly and may need to be
    recycled. Contact your local recycler for
    details. Never dispose of batteries in a fire
    or in water as
    they may explode.
    To remove the battery, follow the
    steps as shown. Use the clear tab
    to help you pull the battery out.
    Troubleshooting
    Your MyFi should provide you with trouble-free
    performance without needing any servicing. If it
    does not appear to be working properly, first try to
    remedy the problem by following these steps:
    1. Attach all connections firmly and securely.
    2. Make sure the battery is fully charged.
    3. Reset your MyFi by removing the battery cover and
    If you see this on the display:
    NO SIGNAL
    Cause: The XM signal is being
    blocked.
    ANTENNA
    Cause: Possible problem with
    the built-in or external XM
    antenna.
    Cause: When using home
    stand or vehicle cradle, home
    or vehicle antenna is not
    plugged in.
    OFF AIR
    Cause: The channel is not
    currently broadcasting.
    LOADING
    Cause: Your MyFi is acquiring
    audio or program information
    from the XM signal.
    UPDATING
    Cause: Your MyFi is being
    updated with the latest
    encryption code.
    Cause: You may have tried
    to tune to a channel that
    you have blocked or that
    you cannot receive with your
    subscription package.
    You should:
    Move your MyFi away from
    obstructed area, e.g. an
    underground garage.
    Connect the external antenna.
    Make sure the cable and
    connector are not damaged
    or kinked.
    Make sure the home or vehicle
    antenna is plugged into the
    home stand or vehicle cradle,
    even if the wearable antenna is
    already plugged into the
    receiver.
    Tune to another channel.
    This message should
    disappear in a few seconds
    in good signal conditions.
    Simply wait a few seconds
    until the update is done.
    To receive that channel,
    contact XM Satellite Radio
    at 1.800.967.2346.
    for more details check out this linkhttp://shop.xmradio.ca/site/xm_radio/assets/pdf/Delphi_MyFi_SA10113_User_Guide_EN.pdf
    thanks.
MYFI XM2GO WILL NOT TURN ON. ALSO WHEN I PUT IN CRADLE WILL NOT SHOW CHARGING
I had the same problem. This procedure from the "Technical Questions" section of http://shopdelphi.com/consumers/support/faqs/myfi/ worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My Delphi XM2GO MyFi has stopped transmitting to an FM station on a house radio. Is it repairable? If so, is there a facility in the Cleveland, OH area where I can take it?
IF you take it out of the home dock and run it on batteries, I'll bet you it works again. The newer home docks TURN OFF the FM transmitter. Try a car dock, or try it with just the power plug plugged into the bottom of the MyFi, without the home dock and see if you can now get the FM transmitter to work. Let me know. Thanks and good luck.
Aug 09, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
How do I take apart the MyFi?
take off battery cover, remove battery, remove 'cardboard' and any screws you can see under the cardboard, Then carefully pry apart. There is one small cable that goes from the antenna jack on the side to the top, and another small cable for the built-in antenna at the very top. Both are VERY VERY fragile.
Jan 16, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My myfi is out--
radios are junk, manufacturer does not support their product. I bought two of these garbage units....stupid me. everyone has the same problems with this unit so obviously it is a manufacturing failure...plus we get no support for the hundreds of dollars we paid out on the units...
Aug 08, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
MYFI does not powerup
You may not be getting power through the base because of a bad physical connection between the base pins and the receiver, and it won't power up because it has no battery charge. Try plugging the AC power adapter directly into the bottom of the receiver (not through the cradle). Push the adapter plug toward the back of the receiver to see if the + sign on the battery on the top right of the screen shows that it is now receiving power and charging. Alternatively, with the receiver in the base, try pulling the top of the reciever toward you to tilt the receiver forward on the pins to see if it starts charging.
Sep 04, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
MyFi FM Modulator Stopped Working?
hi there..there are few ways on installing xm into your car..you can use the FM Modulation that you're doing before..it goes like this...make sure that you're xm radio is turn off( with all the wirings unplug).....then, you just have to go on a blank channel(e.g 90.1) on your car radio...afterwhich, turn on your xm radio and go to MENU....and look for FM settings...and select the same frequency you have into your car radio...and just have to wait for 5 to 8 secs and you should be getting the prev. channels.....
IF: you're only getting prev. channels such as 1, 130 etc...you just have to call xm to send a refresh signal OR you can go to www.refresh.xmradio.com if you want to save more time...just type in your 8 digit radio I.D....
IF:
you're not getting the FM settings.....you just have to click the MENU and select the 'default settings/factory settings' then turn off/on your radio to save the changes...
i'm sure it'll work nowq at this time....Godbless!
Aug 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi MyFI
I have the same problem, and only the same few channels are shown on the channel access screen and they all have + signs.
Aug 21, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
try doing away with the external fm transmitter and use the one thats built in to the delphi you just go into settings and set it to a station that has no channels and tune it in
Jun 13, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
MyFi remote control has stopped working
ok take the battery out of the radio then put it back in and it should work mine did the same thing to me
Nov 24, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
My XM Delph MyFi won't "record"
I get the same problem once in a while. Try removing the back cover and hitting the reset button via a paper clip--then try accessing the stored content. The MyFi should "release" the stored content.
Dec 13, 2006 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
37 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
