Question about Hoover Dryers
Hoover dryer TC650 tripping RCD
Please can anyone offer some advice. We have just purchased a second hand Hoover condenser dryer (Six. TC 650). I'm sure the lady was honest but when we got it home and tried it - it tripped the RCD switch and everything goes off! I've replaced the fuses in the plug and no improvement. When I press the on button and set to dry it works for one second then trips again. My suspicion is that when we drove it home we laid it down on its back to get it in the car and this may have moved water around inside - there seems to be a slight sloshing sound  when I manually turn the drum. Thanks for reading this - Any suggestions???
4 Suggested Answers
  • 87 Answers
SOURCE: dryer tripping electricity saftey switch
You probably have a shorted heating element.
Posted on Jun 08, 2007
apart4u
  • 213 Answers
SOURCE: I turn my indesit is70c tumble dryer on and after
this could be the hater or the motor but sometimes just chafed wireing
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "h_WMwQ-M33A" placeholder (do not delete)
We have a full video library on appliance repair video’s
Posted on Jan 08, 2010
barkencoa
  • 3463 Answers
SOURCE: Dryer tripping RCD
Try disconnecting the heater and thermostats.
They are located behind a removeable cover at the rear of the dryer.
If it still trips, then the problem is likely to be more serious.
Hope this helps.
Posted on Jan 19, 2010
Advice on RCD tripping
yes
an accredited electrician can test the circuits for insulation failure , vermin shorting across active / neutral/ earth points and the rcd itself
it is not a diy job
May 12, 2017 | Ovens
HOOVER TC650 need to replace drive belt how to access the motor ?
The TC650 does NOT disassemble in this fashion..... Pleas read the posts properly or you are wasting your time and the readers trying to fix faults.....
Oct 10, 2011 | Dryers
Our hotpoint ctd40 condenser dryer aquarius trips our household rcd panel when you try to start the machine all the power lights are on and it does not blow the plug fuse. I have cleaned all the filters...
I would get an electrician to check the machine as it appears to have an earth fault on the machine wiring , This type of fault will operate the RCD quicker than the fuse will operate. I am a qualified electrician by trade.
Feb 04, 2011 | Hotpoint Dryers
Condensation builds up inside machine during cycle and trips out the electric
i cant see condensation being the problem. as washers are designed to withhold this factor i belive there is an earthing problem or/ pos/neg leak causing the washer to trip the rcd. have it looked at by a service tech
best of luck
Nov 28, 2010 | Hoover HW130M Front Load Washer / Dryer
Dryer tripping RCD
Hope this helps.
Jan 19, 2010 | Hotpoint Dryers
I have in indesit tumble dryer model no;-IS70C.When i hit the start button the machine cuts out right away and trips the main socket RCD in my fuse box.Sometimes the machine starts and then cuts out again...
Hiya drodger, i had the same problem with my hotpoint dryer, (same company) if this is a condenser dryer make sure the drawer is collecting the water there is a small hole at the bottom of the drawer if you have a straw poke it in and clean it out, also at the back of the dryer there is a clear plastic pipe and a black one take them both off and clean them, your problem is exactly the same as mine so you will probably have to buy a new heating element (they are a lot cheaper from ebay) they are so easy to fit just 2 clips (i did it and im not dead yet!) hopefully you will then find the dryer will work perfectly, word of advice though clean the collecting drawer out at least once a month.
Hope this helps
Sep 27, 2009 | Dryers
My Hoover TC650 condensor dryer has a fault. When turned on it makes a noise (buzz) but the drum does not revolve. If I turn it by hand and then quickly close the door and press the button it will...
i saw your question and never worked on a hoover dryer so i checked it out go here to see video
https://www.how-to-repair.com/help/hoover-candy-tumble-dryer-drum-not-turning-and-belt-ok-faulty-capacitor/
i have to tell you on all the dryers i've ever worked on they never had a cap in them,only washers,on a dryer that isn't a condenser dryer if you get the dreaded buzzing sound and start it like you did,open the door,hold in the door switch and spin the drum with your other hand while someone else pushes in the start button and it would start it would be the motor,i've seen a condenser dryer and the problem always was with the filter,people that had just bought one didn't know you had to clean out the filter box,never took one apart,i saw that nobody answered you so i hope this video helps you out and i learned that condenser dryers have a cap in them.
Dec 30, 2017 | Hoover Dryers
Hoover six tumble dryer runs for about 15 minutes then trips the electrics, condenser has been cleaned and water container is always emptied
usual cause is water being thrown by the fan onto the heater. after this has happened, remove cover over heater and see if water is present.
the water is there because the water path from condensor box to pump housing is blocked with lint
Sep 17, 2008 | Dryers
Dryers Logo
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
