Question about Honeywell Heating & Cooling
How do you hook up the wires, we have seen videos and they are putting the wires in on the top. we have model #rth230b. thanks
2 Suggested Answers
SOURCE: Help! replacing WeatherKing thermostat with Honeywell RTH230B
RC AND RH CONNECT BOTH WITH RED
Y TO THE YELLOW
G TO THE GREEN
W TO THE WHITE
Posted on Sep 18, 2009
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
I have a four wire system one is white red blue and green and i just bought the rth230b where do i put them at exactly
Red: Power (24 Vac) Green: Fan White: Heat Blue: Common
Now I would check those at the furnace BEFORE you hook the wires up.
Nov 21, 2009 | Honeywell Programmable Thermostat Heater
I have a lux product thermostat model #t101141/psm30 and the connections are not working with the new rth230b thermostat. what i am doing wrong.
you are likely missing a Jumper wire between RH and RC ....if you have 4 thermostat wires , usually Red,White,Yellow and Green...then you will req the jumper wire...look at the old thermostat and see if it had 1...install this jumper on the new one....obviously also make sure you have the wires connected to the appropriate terminals....you may also have blown a small fuse in the furnace while installing it if you did not turn the power off first or hooked the wires up incorrectly
Oct 25, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Y TO THE YELLOW
G TO THE GREEN
W TO THE WHITE
Sep 18, 2009 | Heating & Cooling
I have Honeywell thermostat (RTH230B). The heat set works well, but cool set does not work. My air condition works well with my old thermostat. What's the problem. Thanks
Do you have an Rh and Rc terminal on t'stat and do you have 4 wires coming into it?
If you do then you need to put a jumper wire from Rh toRc.
Sep 10, 2009 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
I have my temp on C and I need to change back to F I have the RTH230B programable
May 30, 2008 | Honeywell Programmable Thermostat Heater
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Feb 03, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
