Question about Bush 5693D 24" TV
White line horizontially through middle of picture
I have a bush 2167ntx. This telly is a few years old but was working perfectly untill yesterday ,when I suddenly got a thin, bright, white line going horizonialy accross the screen. This has split the picture in the middle. You can still see all the tv picture but the top is a bit distorted (wavy grey lines running accross horizontially) I unplugged the tv set over night and disconected vcr/ dvd. I have tried a different aerial. The line shows on all channels I have no tv fixing knowledge. My loal tv repairer would need me to take the set to his work shop and wants £50 just to look, before quoting. Would it be sensible to do this? or get a new telly? Thanks kaz
    President:
  • 3,130 Answers
A repair like this is in the vertical drive/output section of the TV set. It could be a simple capacitor causeing this problem or a combination of the capacitor and the output IC. A repair like this should not exceed 120 to 150 US. Is it worth that to you? How much can you replace it for? Good Luck PS please dont forget to rate this thread.
Posted on Oct 25, 2006
SOURCE:
Only the top half of my Philips 170S LCD monitor displays a normal picture. Below this there is a one pixel wide white line and then the bottom half of the monitor has a lined pattern that gradually...
If the monitor is connected to a DVI output on your computer try to connect it to the VGA to see if it's an issue with the input or if the monitor is shot. It sounds like your monitor just crapped out.
Jun 06, 2017 | Philips 170S4FG 17" LCD Monitor
I have had my sanyo flat screen tv for 1 year. The picture on 4 different stations is "snowy", the rest of the channels are fine. On my Sony DVD player I get audio but no picture. It is also 1...
These units are close enough to the warranty end period that I would suggest that you contact Sanyo and Sony requesting warranty service. Talk to a supervisor and be persistant. It may take a few calls.
Keep us posted.
Dan
Apr 18, 2008 | Televison & Video
I have a LCD 42" telly. I had it few years now.
Your telly has died a noble ***** and may need to be retired.
T con board is responsible for images portrayed on screen.
Aug 25, 2017 | LG 42LC2D 42 in. LCD HDTV
I have a bush colour tv and there is a blue,green,red colour wash right across the picture so people''s faces look half blue,green red....sort of as if there is a rainbow across the screen.. i do not have...
It sounds like your TV may need degausing.
Is your TV situated near to any loudspeakers or other devices with large magnets inside them? Or has anyone been near your TV screen with a magnet???
You need to try to get the screen demagnetised (degaussed). Many TV engineers have a degausing coil that could do this. It only takes around 20 seconds at most.
Some TV's like Mitsubishi have a DG button on the remote, that does this function without the need to call out an engineer! It only needs one press of the button every few years!
Nov 17, 2009 | Televison & Video
White lines
This camera is nine years old. It is worn out. Replace it.
Jun 04, 2017 | Kodak EasyShare M853 Digital Camera
Line through the middle
socer, solder connections on the vertical output IC are broken, board has to be taken out and re-solderering the pins on the vertical IC will fix it easy job for a tv tech, good luck, BMW Rider
Jan 03, 2008 | Proscan PS36123 TV
Fluttering
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 10, 2007 | Mitsubishi VS-60607 TV
Bush 5693D 24" TV Logo
297 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
