Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
I need to get the blade of the lawn mower sharpened.Any tips on how to disconnect the blade fropm the lawn mower?
    Scholar:
  • 62 Answers
There is a jig that you can buy that makes this job SO much eaiser. It is a universal jig that clamps onto the deck and keeps the blade from spinning so you can use a ratchet to remove the nut holding the blade on. One name brand is called a "Blade Hog". You should be able to find one of these at one of the bog box hardware stores.
Hope this helps,
Chad
Posted on Nov 09, 2008
How do I take blades off to sharpen them?
raise the mower put a block on the rim of the deck so the blade does not turn remove the bolt on that holds the blade in place sharpen and replace in reverse order
May 27, 2017 | Craftsman Garden
Not cutting
If the mower starts and runs, then shut it off.
Find the spark plug.
Now, tip the machine up on its side WITH THE SPARK PLUG UP.
(If you do not, and if you tip it the wrong way, you can fill the combustion chamber with oil and ruin the machine when you try to start it again.)
Once it is tipped, look under the machine, and feel the blade to see if it is tight or loose on the motor shaft, and also if it needs to be sharpened.
If loose, tighten it.
If dull, sharpen it.
God bless your efforts.
Apr 12, 2016 | Garden
Why is my electric Black and Decker lawn mower still vibrating and loud after I replaced the blade insulator and fan?
disconnect all power and turn the mower on the side
turn the cutter blade /base by hand and watch the centre bolt or shaft
if it moves in a bit of a circle then it indicates that the motor shaft may be bent, causing the vibration at speed
Aug 03, 2015 | Electric Garden
Procedure for removing spindle blades for sharpening
The blades on the spindle do not require sharpening. It is the single blade at the base of the lawnmower that requires sharpening.
Feb 09, 2015 | Garden
How do i remove the cutting blade from a morrison 500 reel mower
Disconnect spark plug wire. Turn on side. Block blade from moving using a block of wood. Loosen blade blot with appropate wrench or hindge handle(breaker bar) and socket.
Oct 19, 2014 | Garden
Lawnmower blade turns but does not cut
You have either bent the blade and its to high to cut or you need to sharpen the blade with a grinder.
Aug 01, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
151 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
