Question about HP Pavilion ze2000 Notebook
Cooling system my fun has problems when it comes to cooling the laptop. it runs slow and at times does not start running even when the laptop is warm. What should I do?
    Master:
  • 474 Answers
First of all, iclude all this in one post please, not four. Reply to our answers and questions, dont creat a whole new work order, it gets hard to keep track.
Your heating issue coul dbe several things and is most likely what is causing the display issues you spoke of in another post.
Try cleaning out any vents and fans with compressed air. While its powerd off of course.
When using a laptop, it should be on a flat, hard surface to distribute heat easily from it to the surrounding area.
If heating is still an issue, try getting one of those laptop coolers that run off the USB port, Walmart sometimes has them, Best buy and most computer stores have them.
See if this helps.
When the processor over heats, sometimes it can melt the wires for the monitor, especially if the ribbon lays over the cpu heatsink.
Posted on Dec 01, 2008
MY 29 DFI KAWASAKI MOTOR BACKFIRES WHEN TRYING TO START
Once you get it started and warmed up, do a timing check with a timing light. It sounds to me like the timing is too far advanced and that causes the backfire when trying to start but will run fine when warm. Over-advance can cause pre-detonation at the plug and can burn a hole in the top of your piston, even though it runs fine. Reset your timing.
Nov 11, 2017 | Cars & Trucks
Hi, My laptop taking so much time to switch on and it became very slow. Please tell me the soluiton for it.
Sometimes slow booting of computers and Laptops are caused by viruses and spywares. Also, a High temperatured Processor makes a computer slow.
Here are some solutions you might want to try.
  1. If you have a installed antivirus in your computer, i suggest you update your Antivirus and then Start scanning your computer for possible viruses and spywares.
  2. If viruses and Spywares are not the problem, maybe your Processor is feeling to much heat. I suggest you use Laptop Coolers like this one. heifentrixx_11.jpg
  3. This will help you cool down you Processor and Laptop.
Hope my solution will help. Thanks for using Fixya!
Jul 08, 2011 | Toshiba Satellite Pro L300 Notebook
How can I tell if the fan is bad or if it it not being truned on? Dell Inspiron 1501
On a laptop this can be a slightly annoying thing. The fans are normally set to run only when needed so will not be working all the time. If your laptop is warm/hot then you should be able to feel some air movement from the exhaust vent. That will tell you if the fan is working. Use it for a while and then start checking around the sides for any warm air coming out. The fan itself might be quiet but you can feel the warm air.
You can also turn the cooling setting to max cooling through the power panel. That should force the fan to run all the time.
If the fan is running but you can't feel any airflow then the cooling system/vents may be plugged with dust or lint and need to be cleaned. Most computer shops will offer a flat fee to clean this. Usually the service depot will as well. If this is the case you really don;t want to run the laptop until you get it cleaned. Without the airflow the cpu will overheat. At best it runs slow and at worst it burns out.
Nov 09, 2010 | Dell Inspiron 1501 Notebook
My gateway MA1 laptop running win xp has cooling problems
Contact GATEWAY, and get them to fix your laptop.
The fan is designed to run at "full-speed" when you first turn it on, and then there are temperature sensors that slow the fan down, to minimize noise, while the computer is "cool" enough that the fan does not need to run. The sensor is malfunctioning, and is not turning-on (or turning-up) the fan when the computer gets "warm".
Jul 17, 2010 | Gateway Computers & Internet
My Dell inspiron 1520 has been running slower for a few months now, however now when i load WoW it funs like normal for a short time and then the Fps crashes. When this happens Videos and anything...
It almost sounds like your graphics card is overheating or causing your system to overheat after a while of playing. This would definitely cause your computer to slow or even come to a halt.
Try cleaning out the dust and make sure the fans are running well. You may have to add more fans or replace the ones that are in there. Also, if you are using the computer in a hot environment, you will need some other source of cooling the components such as liquid cooling.
I hope this helps :)
Best Regards,
James
Jul 21, 2009 | Computers & Internet
Acer Aspire 1690 cooling problem whit windows vista
Windows Vista is a very demanding Operating system when it comes to system resources and it doesnt come as a shock to hear that you computer runs warmly, If you werent experiencing any problems when you had windows XP installed, I would suggest downgrading to Window XP, otherwise wait for October 22 and purchase a genuine copy of Windows 7 and use that.
Jun 18, 2009 | Acer Aspire 1690 Notebook
Fan goes on way too often
Need to clean out your fans and cooling fins around the fan, cpu and the vents inside and outside computer. Check to make sure the fan isn't slowing down. Bad bearings in the fan will cause more friction and cause it to run slow and not cool as well.
Jun 08, 2009 | Acer Computers & Internet
Help!! my dell 6000 laptop has been running without a battery installed, only been using the power cord. The first time I turned it on today, the company freezed after all the desktop icon and start up...
No running the laptop without a battery will not hurt it in any way. I would suggest like you thought that it's a cooling problem. It may need the cooling fins cleaned out and silicone grease reapply'd to the processor and heatsinks.
May 07, 2009 | Dell Inspiron 6400 Notebook
My HP Pavilion is running slow now, fairly new. How do I fix it?
Is the reaction time slow like opening up apps? Is it reading all the ram installed?And if all that is fine then there might be a program in the backround taking up your memory
Feb 27, 2009 | HP Pavilion dv6000z Notebook
My house have a gas heating and electric cooling system. When I turned the cooling on the outside fun started but the cooling system inside house does nto start. I tried heating system it dose not start...
if the fan outside is running then feel the compressor outside or listen to it if you can notice that the compressor is running the same time the outside fan is running also.
it could be that the compressor is not running.
but if you can notice that the compressor is making a different sound as it turn on, then the compressor is running but not cooling, then you could have a leak problem. there is no or little refrigerant in the system.
if you have a leak, please contact your local repair man to do it.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Heating & Cooling
HP Pavilion ze2000 Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
