Question about Sentry Fireproof Safe
Sentury Safe - I pushed the buttone on the front and can't open the safe
The security button on the front of the safe, just below the combination dial, and now I can't open the safe. HOW do I get the safe open
Vballsb@hotmail.com
Brian
5 Suggested Answers
  • 9 Answers
SOURCE: sentury safe Model MSW3517
go to this website.....
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
if no help from there its worth the $12 to ask for their help, because having a safe is def. worth $12.
Posted on Feb 08, 2008
dmathwizard
  • 113 Answers
SOURCE: Sentury Fire Proof Safe 1250
I concur with ohiotom but I will use this as a suggested solution in order to get this off the board.
You have to contact Sentry directly to get another combination
Sentry Safe
1-800-828-1438
www.sentrysafe.com
Posted on Mar 05, 2008
Is there any way to crack the safe by feel, ive seen it done before and have some experience in opening locks with pin tumblers, but not wheel tumblers. i can find the notch in the third wheel at around 10-15 but i dont know where to go from there. I would not be using this information for any illegal use, i just need to open my safe on my own, and soon, thank you.
Posted on Sep 21, 2008
HI , I have the Sentry Safe Model # MSW3517. After 10 months of owning this safe the batterys went bad. I replaced the batterys with new ones and the safe still would not open.I checked online and so many people were having the same problem. I called customer service, Who told me to bang on the safe door with a rubber hammer ( What ever are they talking about ) I studied this safe design and found out that the battery holder went bad.Not making a steady contact with new batterys, Went to my local radio shack store and for ( 1.99 $ ) replaced the factory battery holder and now the safe opens with no problems..Very cheap and simple fix.You will have to cut the 9v battery connector plug off the red & black factory wires to connect the new battery holder for this to work.Very easy to do.. goodluck....
Posted on Jan 18, 2011
  • 42 Answers
SOURCE: I have a Brinks Fire Resistant safe Model number
https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
Contact Sentry. They can give you a default combo so you can reset it and program it with your own and get inside.
Wish you luck!
Posted on Mar 10, 2011
Reset gun safe combination
I have a similar safe, although it is a different brand. I have a red button under the top of the safe, around where the battery's go in. I have to hold that button until I hear a beep and a red light flashes. Then I'm required to input the new combination. This may, or may not, work for you.
I recommend contacting the manufacturer and asking them.
Apr 28, 2013 | Safe International Adg Sports Secure Vault...
How to change combination of model 1250 sentry fire safe
dear sir i was given a sentury safe#1250 ,serial #g969560 the safe is open how do i figure out the combination?
Feb 08, 2013 | Sentry Fireproof Safe
No override key to open the safe and need to change battery
is there a reset button in the sentry safe X055 that i could use to reset the password
Nov 15, 2012 | Safe International Sentrysafe X055...
I forgot the combination to my ms0100 sentury safe how do i get in to it
I use my safe everyday and I when I got off work.tonight just like every night I went to open my safe and it will not open I've tried many many time trying the combination different ways (which I knew probably wouldn't work but was that desperate to try everything to open it) I really need what's inside my safe please help me!
Mar 06, 2012 | Home Security
I have a sentry safe model so500 & the batteries are dead, so I can't open it. I know the combination, I just can't open it! HELP!!! thank you, Lesley
Locksmiths agree on How to install sentury safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
Aug 07, 2010 | Sentry Fireproof Safe
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Operating Systems
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Jun 30, 2009 | Safe International Digital Electronic Safe...
Need instructions for a Brinks security box with keypad and key
Push button in the back, enter 4 to 6 code and push the pound key.
To check combo push star, enter your code, push pound. Safe will beep three times and turn your key.
Jan 30, 2009 | Check Point Network Adapter
Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
How do I insert the batteries on my advanced electronic lock safe?
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jan 26, 2009 | Sentry Fireproof Safe
Jan 26, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
49 people viewed this question
Top Sentry Home Security Experts
xenophanes
 Brian Main
Brian Main
john h
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
