Question about HP Pavilion dv6000z Notebook
Medion notebook pink will not start up
The battery lights up green, so I assume it's not that..where to go from here?? totally dead..:(
  • BRIAN REISS
    BRIAN REISS May 11, 2010
    PLEASE ANSWER THIS. IS THE AC ADAPTER CONNECTED TO THE LAPTOP AT THIS TIME? IF NOT, WOULD YOU PLEASE CONNECT IT TO THE LAPTOP AND THEN TRY TO BOOT THE COMPUTER. REPLY WITH RESULTS TO: ARCLIGHT1217 AND WE WILL PROCEED. THANKS!
  • 689 Answers
Take the battery out disconnect the power cable then press and hold the power button about 7 seconds. After that but the battery in connect the power and turn it on. It will work if the issue static lock up. If you need further assistance please post.
Good Luck
Posted on Nov 10, 2008
Ezip
The light came on because the charger brought voltage up to full, but when you hit the throttle, the voltage dropped since the charger cant power the motor. While checking the wiring (which I assume people automatically do), bypass the power switch with a screwdriver or a jumper wire. If it works, replace the switch. Check the battery with a multimeter...you should get > 25.2v full charge, no load. If you get 0v, check the fuse in the battery case. If all of the above check out ok, and it's totally dead, you probably need a controller.
May 28, 2013 | Currie Technologies eZip Mens Trailz...
Battery power indicator light has suddenly stopped coming on. Can I still use my laptop?
If it works, yes you can. It maybe that the battery went dead.
Try removing the battery for 10 minutes and put it back and see if the laptop powers on. If it doesn't, connect the power cord and see if it is charging. If not, then most likely battery is dead.
You can buy batteries from stores like ebay.
May 03, 2011 | Medion MD-41017 Notebook
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
My computer will not turn on. There is power to
In order to check that, you can try this:
- Remove all power sources
- Remove the battery
- Turn on the computer again with no battery
Please get back for any clarifications.
regards
Sandeep
Oct 19, 2009 | Sony VAIO VGN-FS980 Notebook
Microstar MID2020 notebook not booting up
first check the ac adapter even with a green light,(on the adapter) it could be bad
next if you have to wiggle the cord in back it could be possible dc jack pin is loose ,and may need to be replaced
Jul 19, 2009 | Medion MD-40954 Notebook
URGENT! My computer doesn't switch on and Ihave a tight schedule.
please try a different ac-adapter, since its most likely defective.
if the powerled just blinks 1 time it usually indicates that the battery is empty and need to be charged.
May 29, 2009 | Sony VAIO PCG-K35 Notebook
Medion 2080 notebook battery wont charge
Time for a new battery. If you have a batteries plus in your area or order online.
Aug 13, 2008 | Medion MD-40954 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
HP Pavilion dv6000z Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
