Question about Whirlpool Water Heaters
How to drain hot water heater
My hot water heater is in a camper. I am trying to drain it for winter . I can't find a way. model #61f6uso15v
  • 104 Answers
Look under camper at floor
Posted on Nov 11, 2008
I bought this camper and it has a Atwood water heater in it and i don't no anything about it, how to light it
Copy following link:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Otherwise there are 100s of atwood water heater resources on internet covering the different models old and newer
Jun 05, 2013 | Water Heaters
Draining down in winter
Which type and brand water heater?
Tankless?
http://waterheatertimer.org/pdf/How-to-drain-tankless.pdf
Tank type?
http://waterheatertimer.org/Water-heater-will-not-drain.html
Boiler, solar, indirect, hybrid, combo, heat pump, etc?
Most have a drain valve.
Nov 02, 2012 | Water Heaters
How do you winterize Model GE20P06SAG? There is no drain at the very bottom...?
Thank you for including model number for EZ identification of water heater
To drain tank without drain valve: Remove TP valve at top of tank and siphon out the water. Then reinstall with correct pipe configuration shown in product manual.
Product manual shows drain valve is not supplied with this unit.
http://waterheatertimer.org/pdf/GE20P06SAG-under-counter.pdf
Product manual shows the Installer should add both shut off valve and drain valve on cold water inlet line.
http://waterheatertimer.org/images/GE20P06SAG-under-counter-60.jpg
More resources:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Sep 30, 2012 | RELIANCE 19.9 Gallon Electric Compact...
I have a Park Model RV with a Rheemglas Fury model 81VP205 with no bottom drain. How do I drain the water heater to winterize for the cold Northern Winters?
Make sure it's off (hydro) and open drain at cold line going in bottom wherever you find a drain (usually close to it) going down through floor and outside under trailer. Follow cold line back until you see a line "T" and one line going down under trailer, and open it up underneath. Then open pressure relief valve at top of tank to allow for faster draining .
Oct 14, 2011 | Water Heaters
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Should I drain and ?clean? out the water heater...13+ years.. model pgcs 50 102H It runs out of hot water increasingly quicker
I assume your is an electric hot water heater. Is your water "hard" in your area? If so, it would be worth a try. What usually happens in a heater your age is that sediment builds up causing the lower element to overheat and burnout, causing less hot water to be produced
Mar 03, 2010 | Water Heaters
I have model gc6aa-9e water heater. I think i blew the 120 element by turning on breaker B4 filling water tank after winter; The schmatic that came with camper shows part # 91160. Is this corect and if so...
Yes, That will do it. Most RV appliance parts can be purchase at RV dealerships that have parts department. Camping world has always been very helpful. As far as A part # is concerned I can't confirm although it is good to have it and the make and model of the unit. Good Luck
May 08, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Water pump does not work when i turn on hot water tap
Since the cold water works, the problem is not the pump. Look for a blockage or possibly a major leak in the hot water system. if you have a kitchen sink and bathroom sink, are both hot water outlets not working? Does the water heater have shut off valve , or is its drain still open from when you winterized it (and the water running out to the ground instead of to the faucet?
Apr 22, 2009 | Water Heaters
Water Heaters Logo
476 people viewed this question
Top Whirlpool Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
80stech
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
