Question about Compaq Microportable 2810 Multimedia Projector
Projector overheating and turns off after 20 mins
Quick Question oh mighty one, 2810 Compaq projector, manufactured 12/5/01. Overheating and turning off itself. Cant find a person to fix it in Ireland, surprised....not me!!!. Any quik solutions to the problem please.
  • 2 more comments
  • damuche007 May 01, 2008
    i have same problem with my dell 3400m projector, and it will cut off every 15min, i just change the bulb and same problem still happen
  • polywog_95 Sep 19, 2008
    I have an InFocus projector that is abt 3yrs old, however, we do not use it that often. I too have started having that same problem. It will run a movie abt 30min. tops then just shut off. I don't think its the bulb because the bulb life is approx. 2000 hrs and I have only used abt 200hrs. I am lost as to why it is getting so hot and shutting off so quickly....any suggestions?
  • mogman8 Nov 16, 2008
    Mine shuts off after less than a minute of run time and the projector says it only has 787 hours on it. Indeed turning it upside down takes care of the problem but I'd like to see if there is a better way of doing this.
  • Vic2rtot Jun 12, 2013
    this was happen to me, i fixed it by disassembling, i checked the fan, cleaned it, put a thermal paste into the heate sink, and now its working with no issues.
    Problem Solver:
  • 5 Answers
I have a HP VP6111 projector that works fine on a table top but overheats ( overheating ) when turned upside down and hung from my ceiling. My solution...I went to Circuit City and bought two 80mm computer fans. I also purchased a 12V power supply from Radio Shack. I put one fan on front of my projector and the other on the back of the projector and wired them into the 12V power supply. I mounted both fans with velcro. The front fan pushes air and the rear fan pulls air. The projector now runs fine without shutting off. The fans are 12V and push 34 cubic feet per minute of air. I am very happy with this solution.
Posted on Dec 27, 2008
After lots of research on this, the problem appears to be with the bulb. Once the bulb gets 'tired' the filament becomes 'stranded' and the running temperature increases massively. The safety mechanism of the projector cuts in before serious damage occurs. Interestingly, using big external fans didn't solve the problem, but turning the projector upside down does (presumerly the heat sensor is at the top of the projector). Solution: Buy a new bulb, or for what bulbs cost, but a new projector!!
Posted on Jul 27, 2007
  • 4 Answers
It stays on for 15 or 20 mins then light goes out but sound still plays with light out,then 4mins later it comes back on
Sounds likely that the projector is overheating. Try removing and carefully cleaning the filters over the air inlets. Carefully washing them in warm water and squeezing dry is usually satisfactory, but DO NOT replace in the projector and turn on until the filters have had at least 10 - 12 hours to thoroughly dry out.
Mar 29, 2014 | Christie DS+60 Multimedia Projector
Compaq MP2800 DLP Projector
If the projector is not getting a source it might go on standby maybe check where you plug it in.
Projectors require quite a bit of power and should be on a single loop/outlet not hooked up to a powerbar with more things on it.
Hope that helped.
Dec 26, 2007 | Compaq MP2800 Microportable Projector sps...
Pt-ax200u projector turns off after 1 min of operation. the light turns red then green. After that, the power button does not respond and i have to cycle off the project. If I turn it on, it does the same...
your projector is detecting it is overheating, check that nothing is blocking the vents and that the fans are not clogged. If the vents and fans are dirty clean thema paintbrush and hoover. If they arent then the lamp maybe the culprit
Mar 07, 2011 | Panasonic PT-AX200U Projector
When i first turn it on the message (projector over heated will automatically shut off lamp) comes up and then shuts off after 2 mins
You have an overheating problem.To solve it
1) Ensure that there are clear air pathways around the projector
2) Clean the air filters.
3) Ensure that the fans are running. If the fans don't run the projector won't fire it.
It is likely that cleaning the filters will solve your porblem.
Feb 15, 2011 | Optoma EP716 Multimedia Projector
New bulb, fan working, after 10 mins of operation get posterized image; suspect overheating; dust has been cleaned out; has not been taken apart
Hi!
Is the projector placed in a box or an area where it could generate overheating? Is this projector still within warranty?
Please feel free to update me. Cheers!
Feb 04, 2011 | Optoma TX1080 Projector
The compaq keeps shutting itself down... I turn it on... It turns itsel***. What should I do?
The device is either not receiving enough power or overheating. Overheating damage can be permenant.
Get one of those compressed air cans and blow all vent out with device turned off. Wait a while and try again. I honestly do not think this will fix it but it is what ails you.
Jun 24, 2010 | Compaq Presario 700 470024-192 Notebook
Hi,I have a Proxima desktop projector that I have
right click on your desk top and check the display settings.
May 15, 2010 | Office Equipment & Supplies
I have an Compaq MP1400 projector not working
Hello :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp or moved it out . They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way? That could cause overheating problem and what you see with your projector is one of it's symptoms .
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage .After cleaning the filter always remember to reset your projector .
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE RATE !
Apr 12, 2010 | Compaq MP1400 and MP1800 Replacement...
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
Why would my projector just shut off?
This is probably one of three causes: 1. The lamp has reached the end of its life. 2. The projector is overheating because of dust buildup/position/etc. 3. The projector has an actual problem with its internal components. The lamp on a projector is very special and most likely won't just blow out like a regular light bulb. When a projector lamp fails, it's more like it can't sustain a burn, but probably won't have a lot of trouble starting one. The projector will probably have an indicator or what have you to indicate end of lamp life. If your projector has an air filter, make sure it's clean. Make sure the projector has enough space around it for proper ventilation and that it's on a flat, smooth surface (no carpet). If you rule out lamp life and overheating, you'll probably want to leave the problem to the manufacturer or a professional electronics repair person.
Feb 21, 2010 | Eiki LC-XG110 Multimedia Projector
Compaq Microportable 2810 Multimedia Projector Logo
8,871 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Computer Links
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
