Question about Dryers
Kenmore dryer start button not working
When start button is pushed dryer will start, but as soon as you let go it stops, Can hold button and will run for a few seconds, but then stops totally.
We were able to get it going for one cycle, but not will not start again at all.
Thanks for any ideas...
  • 1 more comment
  • PLL20 Nov 20, 2008
    I have the same problem with my Kenmore Dryer. When start button is pushed dryer will start, but as soon as you let go it stops, However we can use a book / subject to hold button in place and the dryer will run.
  • Anonymous Dec 13, 2008
    Same problem. dryer will click and start, but when button is released it will click and stop.
    We have just replaced the motor, did we mess something up when taking the dryer apart??
  • Janedoe48 Jan 06, 2010
    I just turned on my dryer and nothing is working- tried fuse box in basement everything is ok. Is there a fuse in the dryer somewhere?
When I push the start button on my kenmore dryer it will not start and the drum will not turn.
Posted on Dec 21, 2009
I recently tried to start my dryer and I just get a clicking noise. Is the dryer broke or do I just need to fix the starter?
Posted on Jul 06, 2009
I have a Candy GOU218 when I push the start button it does start the dryer but as soon as I release my finger from the button it stops, It started doing it around a week ago so I had to push and hold
There are push to start circuits used for motors and then there are holding circuits that keep the unit running. This way the dryer stops if the circuit is open due to high temperature or end of the cycle. It seems as if the holding circuit (could be a rotary switch that stays closed while the dryer is running) or a holding circuit relay (stays closed until circuit is broken by the control) has failed.
Jan 09, 2014 | Candy Dryers
Dryer will start when start button is pushed, but as soon as you stop pressing the button, the dryer stops
I would open up the control panel unplug the unit, disconnect the wires to the push-to-start-switch and use a paperclip to attach these two connecters. If everything works you know it is the switch that is bad.
Sep 18, 2010 | Kenmore 67841 Electric Dryer
Dryer won't run when push button it will run for awhile then stop. push button again it will not run humming sound replace starter switch did not help
you have a bad motor,that's what is humming,it's heating up and cutting out,when it cools down it will start again but soon that will stop also
Jan 23, 2010 | Kenmore Dryers
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
PUSH TO START BUTTON DOES NOT WORK
its not the start button check the door switch if broken or actuator is broken you get the results as you dry
Aug 21, 2009 | Kenmore Dryers
Start button doesn't work properly
Hi, You have a motor going bad. The start winding is out on it.
The motor will need replaced.
Vic
Jun 25, 2009 | Kenmore 659 Electric Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Dryer stops
your motor switch is gone you can either change the switch or motor you could try tapping the switch sometimes it will free the contact this switch is on the motor
Dec 09, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
1,518 people viewed this question
Top Dryers Experts
