Question about Toshiba 43H70 43" Rear Projection Television
Wavy lines Hi, I have a Toshiba 43H70 43" Projection TV. Out of the blue yesterday, when I turned it on the picture was very wavy incorporated with horizontal lines across the set. After about a minute or two the TV shuts off. Any ideas on how to resolve or recommondations? Thanks, Ted
  • Anonymous Feb 15, 2008
    I DO HAVE THE SAME TV AND THE SAME EXACT PROBLEM. DOES THIS HAVE ANYTHING TO DO WITH THE SOLDER WIRES OR JUST THE COMPACITORS.
I bought the service manual off eBay for this TV and replaced what I thought were those capacitors and I still have the problem. Does anyone know EXCATLY which ones they are? I have plenty of pictures and a circuit schematic.....
Posted on Sep 19, 2007
    Problem Solver:
  • 3 Answers
This TV uses small voltage regulators. On each side of the regulators is the input voltage and the regulated output voltage on the other side. There are capacitors used for stabilization on the input and output. Change these capacitors.
Posted on Nov 27, 2006
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Posted on Oct 08, 2007
  • 1030 Answers
SOURCE: Mitsubishi 55" Projection TV / Horizontal Wavy Lines at Start Up
this is very common with these sets. the fix is to replace 11 very very smal capacitor on what is known as the hypermodule. The ideal sitation is to replace the hypermodule. if you can find it. I can do this repair. I have done about 10 at the shop. if you need to i would suggest finding someone who is very experence in surface mounted repair
Posted on Jan 15, 2009
  • 10 Answers
SOURCE: Toshiba 42WH36P rear projection TV has wavy lines
remove the front grill and then the acess pannel to the guns . you will find 6 knobs 3 for color and 3 for focus dont touch the focus the 3 knobs you want are pots for color voltage r g b red green and blue turn the problem color to the left and if need b the others also. a little goes a long waw
Posted on Aug 19, 2009
My samsung projection tv has blue wavy lines on top of screen, I adjusted convergence, the blue will not line up horizontally, is there a inexpensive solution?
It means one of the chips has a bad section inside it, both chips and maybe a resistor near them will have to be replaced, involves soldering as each has about 18 pins soldered in
Check with TVrepairparts.com who sells some kits for this by brand and model number
Dec 09, 2012 | Televison & Video
Toshiba Model 51h84
The wavy when cold is a issue with a board in the set--Hyper board--the warmup until it begins to work will gradually get longer and longer.
The blue: look at set on a unused video input--if see faint curved blue lines with some blue visable on the screen the blue screen control needs to be adjusted just slightly down until the blue and curved lines are not seen.
May 15, 2012 | Toshiba 51H84 51" Rear Projection...
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Tv has wavy lines 6" from top and sometimes from the right side a wavy line
heart ach... of having bad convergance amp ic's
Dec 20, 2007 | Toshiba 42H83 42" Rear Projection...
Wavy colors do not line up
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://www.eserviceinfo.com/
Oct 25, 2006 | Toshiba 56H80 56" Rear Projection...
57"H82 Toshiba-- wavy picture
you got somes capacitor bothering you, and nop, there are nothing you can do, but call a tech, the problem could be in the video card or in the power supply but is a tech job....good luck
Aug 08, 2006 | Toshiba 65H82 65" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
396 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
