Hi when starting up the laptop a screen comes up saying 'configuring updates stage 3of3 - 0% complete Do not turn off your computer. then it seems to restart and the same happens again. ca you help????
    Scholar:
  • 60 Answers
Use your OS disk to access the Vista repair tools.
Even for those without an OS disc, Vista has repair tools built in.
To access them, boot the computer, but when you see the “Microsoft (C)” with the moving lines, hold the power button until it shuts down. Now windows thinks it didn’t boot properly, and when you turn it back on, you should get the option to run Windows Startup Repair.
Choose this. When it loads, cancel the scan it starts (it won’t find anything anyway), and choose the text on the bottom that says something like “Show advanced repair options.” which should get you to a command prompt option. (Some folks are saying that it asked for the user, and they changed from the Administrator to their user account in order to get access to a few more tools, including a command prompt where you can run fixes).
You can also get to a command prompt via holding down, or repeatedly clicking, F8 as the computer begins its reboot. - select safe with command line.
note that this may take a few runs through the reboot F8 routine as my initial runs still ended up with the forever loop. Which is why the OS disk route - if your machine came with or you later bought such a disk - is preferred. If you are lucky ebough to have a restore point established, that option appears to work on a little less than half the machines I've run into.
Once you have the command prompt the need is to remove a file “pending.xml” that is causing the forever loop Instead of deleting the “pending.xml” files from the c:\windows\winsxs folder I renamed it, so that it can be put back later if needed.
This seemed to do the trick for me. But if it still hangs on "Stage 3 at 0%" with reboot and hang again forever cycle continuing, just do a repeat of the F8, and select safe mode w/networking. Stage 3 may well continue and finish normally (it didn't for me) but in any case after the second "safe" reboot a boot to normal windows was possible for the folks I was helping.
Posted on Nov 09, 2008
The laptop is stuck in a cycle and won't start keeps saying configuring updates stage 3 of 3 .0% complete it thenthinks about it then screen goes dark and tries to start again. I have tried to reboot and...
Re boot in safe mode and run 'restore point' from the search box. Select a date/time just before the problem update happened. That will reset your date/time to before the update.
Feb 25, 2011 | Toshiba Satellite Pro L300 Notebook
When I turn on my computer the screen reads configuring updates: Stage 3 of 3 0% complete. Do not turn off your computer. Then it goes to shutting down. It starts up with acer, microsoft corporation the...
downloads are either being stopped by a firewall or your system cannot update what it needs to because your missing other updates. if you dont have all required updates some others will not install.try automatic updates.download all critical and recommended updates.
Oct 05, 2009 | Acer Aspire 9410 Notebook
Stuck on updating screen..
Hi there.
there maybe a lot of updates for the computer to configure, leave the PC alone until its finished and reboots, if it doesn't please feel free to post back
Kind regards and thanks for using Fixya!!
Feb 24, 2009 | Acer Aspire 6920 Notebook PC
Stuck on updating screen...
do a system restore and restore it back to a previous date in time, but doing a system restore to a previous date in time will mean that you will loose any configuration done or any software installed after that date
for system restore for windows xp here is a helpfull llink
http://support.microsoft.com/kb/306084
for windows vista
http://www.bleepingcomputer.com/tutorials/tutorial143.html
restore your system to a date when you are certain that it was working fine and nect time it prompts to load updates choose custom and select and install only security updates which are very necessary not all of them.
Further Queries are welcome
If you find my soltion helpfull please do rate me
Feb 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
Stuck on the updating screen
Reboot your computer and when the message appears at the desktop that there are updates available, click on the link to see what updates are available. Make sure any third-party antivirus and firewalls are disabled. Uncheck any that are "Optional" unless you really think your system needs them. Try installing those that are critical/important first, and leave the rest for afterwards.
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Jan 10, 2009 | E-Machines T2742 PC Desktop
I have an acer aspire laptop, when i start it up its says configuring updates stage 3 of 3 0% complete then it will shut down come back on say the same again and shut down again. it will keep on doing this
Maybe you could try the last known good configuration. When the laptop is starting up, wait until the acer screen disappears and then tap F8 on the keyboard before the windows screen comes up. You should get a black screen with some options that say safe mode. The fourth or so option on the list will be "Last Known Good Configuration". The computer should try and load windows. Hopefully that will restore the machine before the update.
If it works it would be a good idea to go to http://windowsupdate.microsoft.com/ and fully update your laptop. This will download the update manually instead of doing it with automatic updates.
Oct 14, 2008 | Computers & Internet
Configuring updates
If it is windows xp OS plz do the following these step.
start the pc in safe mode and select the administrator login then
go to start programme go to acssories select the system tool- selcet the restore option, turn on windows in previous back day and resloved the porblem,.
bye
Jul 30, 2008 | Computers & Internet
My computer keeps restarting itself
  1. Start laptop
  2. When the laptops Logo page closes, start to press F8
  3. You should get a Windows Start screen
  4. If you get a Windows Logo page (the kind you normally get when Windows loads, then reset it and start again.
  5. On the Windows Start page select "Last known good configuration" and press enter twice
Hope that solves it for you =)
Apr 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
