Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fault code 130
When I start the washer it starts to fill with water, then stops and gives the fault code 130
  • Anonymous Mar 23, 2014
    Fault code 130
  • 34 Answers
Rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Comments: Aug 03, 2009 - if it still doesnt work reset the machine by turning it off at the wall and waiting 2mins and start again. If that doesnt work the sensor may need replacing.
Posted on Aug 22, 2009
LG 2131SH Dish Washer giving error code E1
That is a leakage error, pull the access panel and check for water underneath the unit that might be cuasing it to fault out
Jan 31, 2014 | Washing Machines
Fisher and Paykel Smartdrive washing machine won't fill up
Your fault code is 131,RPS faulty.
130. (10000010) Phase 1 to 6 Single Rotor Position Sensor Error
The Motor Controller has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness
between the Rotor Position Sensor and the Motor Controller, or a faulty Rotor
Position Sensor.
Primary Source: Wiring.
Action:
1) Check for corrosion on the edge connector of the Rotor Position Sensor and
the Motor Controller module connector.
2) Check the contacts on the rotor positional sensor end of the hall harness to
see if any have been damaged. (Each set of contacts in the socket has two
wipers. If the distance between these wipers varies between different
contacts, replace the rotor positional sensor harness).
Secondary Source: Rotor Position Sensor.
Action:
Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position Sensor Error
This fault is similar to fault number 130 above but differs slightly in that it is a
continuous condition. See fault code 130 for service procedure
Mar 20, 2012 | Fisher and Paykel Washing Machines
Hello, I have a 10 year old Fisher & Paykel smart drive 9 pride 5.5 clothes washer. Model MW059. When i start cycle, water starts filling and then suddenly stops for a second or two and then repea
That sounds like a bad RPS, you would get fault code 130.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted.
Service manual, You will need Adobe reader installed to view PDF's
http://www.angelsnz.net/ZL3SV/misc/F&P%20Service%20manual%20517735.pdf
Feb 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
My ignis washing machine stops in the middle of the washing cycle and makes a sound, kind of blowing.
there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses.
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. This advice was originally written when most washing machines were hot and cold fill and didn't have error codes. It's now been updated to reflect the fact that these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
If your washing machine is stuck full of water the water needs to be drained out and this article gives tips on how to do this. If the entire washing machine has gone dead leaving the machine full of water it may be worth checking that it isn't something as simple as a blown fuse ( Washing machine is dead, wont start ) in which case if you get the washer going again it should pump the water out itself.
If the washing machine appears to be functioning normally but simply won't pump away the water then the possible causes (in the most likely order) are a blockage somewhere, a pump failure, or an electrical fault stopping the pump from running.
Blockages are the more likely explanation, but pumps can fail.
Dec 31, 2010 | Amana NAV2330AW Top Load Washer
Washer will not spin there is water on the floor and has a fault code of 130 it is fisher+paykel brand model numberWL26CW1
Hi just read your posting.Error Code 130 means your fault is called Single Rotor Position Sensor Error.This component is attached to your motor which is underneath your machine.What concerns me is your machine is leaking.Did the Error Code appear the same time your machine started leaking?The reason I am asking this is because the water could have damaged the rotor sensor.Is the water leaking underneath the machine?Please reply with additional information and I can help you rectify this fault.
Jul 20, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
My machine stops at "delay start", yet the cycle is not complete.
PROBABLY NOT USING ((((H E DETERGENT) REASON FOR ERROR CODES,, POUR A SMALL AMOUNT OF COOKING OIL ON A SPOON AND POUR INSIDE SHOULD SOLVE PROBLEM
Nov 29, 2008 | Hoover AAA160 Front Load Washer
Fisher paykel gwl10us wont fill
Both of you most likely are getting a "RPS Sensor Fault"
On a GWL10, when the motor rotor position sensor fails, it will act exactly like you describe. Many techs incorrectly replace the machine control or the water inlet valve(s). The RPS sensor is much cheaper. If you consult the tech sheet located under the control panel, you will see the fault code for RPS failure and I would bet the farm that the sequence of LEDs displayed when your washer faults out matches exactly with the RPS fault code.
The RPS sensor for GWL10 and GWL11 models is a part # 420296P and canbe purchased direct from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=5
The procedure to replace it is a little involved but a handy person can do it. It would be best to consult the factory service manual and again, that can be purchased from Fisher Paykel Parts direct here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=15
Nov 25, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Washing Machines Logo
1,069 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
