Question about Philips 27RF50S 27" TV
TV turns off by itself
Tv turns off all by itself. model 27RF50 S325 Good picture Chassis 27T800 7629 Any advice on repairing would be great. Thank You
  • 6 more comments
  • trouble266 Nov 09, 2008
    If you mean a muti-meter, yes I have one.  Yes I can solder.  Thank You for your help.
    If you mean a multi-meter I do. I can solder. Thank You for your help.
  • trouble266 Nov 10, 2008
    electech1, I am a novice when it comes to front boards and main boards. I don't suppose any pictures are available?   Thank You
    Electec1, Where can I find the example of the front board?   Thank You
    Electech, I can hear a clicking sound around the area of the power supply when the tv turns off.
    Thanks for your suggestions, but unfortunately I don't know what the vertical IC, etc. are.
    Guess this is above my technical capabilities.
    Thanks again for your help.
  • ttemple Mar 01, 2009
    I have 2 (yes two) of the 27 RF50 TV's, and neither has a picture. Both have horizontal lines moving accross the screen. The authorized repair shop wants $50.00 to look, then plus parts and labor.
    The TV sets should have lasted longer.
  • jason May 11, 2010
    do you have a meter to do some tests? can you solder if needed?
    if so i can help , just let me know
  • 905 Answers
Ok , first you will need to check the controls panel on the front board, take it out of there and make sure that the buttons are not being pushed on and check the sensor for a short or open also the contact switches are not making continuity(short) then also unplug the controls panel from the main board
and please give me a fixya rating so that i may continue to help you with this problem( anything other than a fixya rating hurts our rating as a fixya expert) that is if you belive that my help will be beneficial to you, thanks
electech
Posted on Nov 09, 2008
  • 2 more comments
  • jason Nov 10, 2008
    i can show you an example of the front control board, and how one plugs into the main board , the rest will be you looking to make sure the front control board is not doing some things and of a couple of tests on it with the meter , also you will need to give a fixya rating so i can continue to help , and if you are not happy with my help you can always change it , and that rating also hurts our score , sorry but thats how fixyas doing the rating , so otherwise i will be glad to continue to help you find the cause of the problem as long as you want , thanks
    electech
    can you change the rating you gave me? this is a main board
    front printed control panel board( contact buttons and sensor)
    how it plugs into the main board
    ok then you probably have to replace the vertical IC , but you need to check resistor value in the power circuit and vertical section , also check electrolytic capacitors in the circuits
    check that out then let me know what you get from testing those ,but definately check capacitors and resistors for right now
Picture shrinks on white areas
Is this a power supply problem? You bet. Also old age.
Jun 30, 2017 | Philips 27RF50S 27" TV
I have a RCA 52"
Yes the ATC221 uses the 259296 flyback. If audio works and the on screen menu also comes up but no video its most likely a vertical deflection issue. I would check the vertical IC for signs of bad solder.
Mar 29, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
Had a severe thunderstorm yesterday (7/23/08). Lightening hit the transformer, all power was out for 6 hours. 3 Televisions. 1, hooked up to modem works fine, 1 hooked up to cable reciever only gets static...
Upon researching various websites regarding the Model Number for those 2 televisions that blew out, I found a few other people around the US that had the same problem with similar situations. All involving massive thunderstorm power-outages.
It appears that since out TV's are both 5-6 years old, they are worthless, both covered under homeowners but for almost nothing. It's not worth fixing. So, decided to purchase 2 more lower quality televisions as this will most likely happen again when the next storm hits. Thank god we found out that this is a repeat issue before we purchased a really expensive television.
Jul 24, 2008 | Televison & Video
RCA P52937SG 52" TV Made March 2002
youre having deflection problems could be related to the flyback. But this type of repair is better off with an experienced tech that has the proper equipment and knowledge to diagnose this chassis
Apr 06, 2008 | RCA P52937 52" Rear Projection Television
Tv problem
there is a short circuit from one of the internal wires to the chassis and i believe it is affecting the picture tube due to the field....
Jan 31, 2008 | Televison & Video
RCA Home Theatre System 51 or 52"? Chassis # PTK169PAAS
If it is a "minor" convergence problem you can adjust it by going to the menu and scrolling to convergence and follow prompts A cross will appear when you have reached the correct place and you do the minor adjustments as it says. If picture is bowed you have major convergence problems.
Jan 05, 2008 | RCA 32V420T 32" TV
Screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
Relay "Chatter" with good picture and sound
Sanyo Model AVM-1304 This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on. I can feel the mechanical vibration on the component. The Picture and sound are very good. The chassis is G6Y-13040. Any ideas? This TV has a loud mechanical "chatter" (or clicking)that appears to be coming from RL001 on the motherboard as soon as ther TV is turned on replace relay as it is easily available or make it direct. .
Sep 11, 2007 | Televison & Video
Proscan 50" rear projection TV model S50-700
the life expectancy of a tv is 6yrs depends on how you take care of your tv.it can go for a long time.
Apr 18, 2007 | Proscan PS50700 50" Rear Projection...
Philips 27RF50S 27" TV Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
