Question about Samsung CLP-500 Laser Printer
Printer not recognizing toner
Printer is not recognizing new toner cartridges. All cart. are new oem sealed in the box. Any Help would be helpful. Pete.
Take some fine emery paper to the contact pins inside the printer (the ones that touch against the copper stripo on the side of the toner cartridges … i also emery the copper contact strip … worked fine after that (and after weeks of wasted time on trying all sorts of other solutions)
Posted on Nov 22, 2008
Waste tank not install
Posted on Oct 13, 2008
  • 161 Answers
Too much people confuse CLP-500 cartridges with CLP-510. Although they look the same and even fit inside the printer, the internal chip is not the same.
Posted on Sep 21, 2007
SOURCE:
Just replaced toner K and now says empty
You replaced the Cartridge with a OEM product or third party or a refill. if the last the electronic chip on the toner cart is still telling the machine the cartridge is old so refilling will never work replace the cart with OEM cart,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 27, 2014 | Konica Minolta Magicolor 4690MF...
Just changed the cartridge in our HP1320 Laserjet (genuine HP cart) but the print quality is now much fainter than normal. Still on ProRes1200 setting as before. Any ideas?
If your toner cartridge is not OEM (HP), this is the most common reason. I have personally seen 2 out of 3 remanufactured HP toner cartridges fail right out of their sealed boxes. Don't be fooled by lower costs, test prove most remanu'ed cart's don't give you page yield to justify their lower cost.
Jan 14, 2010 | HP LaserJet 1320 Printer
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
Yellow toner not being recognized with new toner installed
Probably dirty contacts on side of cart. Also if you take out drum and cart unit together, clean copper contacts with alcohol and cotton bud, also make sure in machine where they contact is clean
May 01, 2009 | HP Color LaserJet 5550dn Q3715A Workgroup...
Ricoh CL7100 - Toner Cartridge Error
Not one answer for this problem. It could be the tube going from toner cart to developer unit is clogged or kinked. It could be the dev unit. Get a toner vac and remove toner and black cap and spring and using the round hose end create seal and vac the tube. The part that goes into the toner cart has hole on the very end, it might have broke off (look at another color to verify). The worst case is the toner attraction pump has failed. One fix is shake the toner and reinstall.
Jan 30, 2009 | Ricoh Aficio CL7100 Printer
Toner Cart chip reset for Ricoh Aficeo sp c400dn
I believe you will need to purchase and install a reset chip. You can find them for the Ricoh C410 here at www.cfriends.com (that links straight tothe ricoh page - but if you need to search, type in "c410" into the search field on their site).
Jan 03, 2009 | Ricoh Aficio SP C410DN Laser Printer
Hi my brother MFC 7420 will not recognize the new toner i just added...........i hve done this multiple times before........not sure now why not working.........are the printer gods against me today??
all brother printers and mfc products. if you are using generic tonere or refills, brother products will not recognize the toner cartridge as the refillers do not know how to reset the toner cart. this is priority info. therefor u must use brother oem toner.brother service rep
Dec 22, 2008 | Brother MFC 7420 All-In-One Laser Printer
Cx5500 all in one and use T0731-4 ink cartridges
If you are using a compatible cart and the printer has twice reported the cart as empty when they are new, chances are there is a problem with the printer. You can buy a chip reseter off ebay for a couple of bucks and try resetting the cart. If the machine still reports the cart is empty you either have dodgy chips on your carts or the printer is having problems reading the chip, This could be caused by a bent pin/contact in the print head cartridge receiver.
Feb 09, 2008 | Epson CX4200 All-In-One PSC Printer
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
Samsung CLP-500 Laser Printer Logo
444 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
