Question about Vacuums
Siemens/Bosch Vacuum cleaner
Noticed that you have a similar problem to mine. In my case, the belt from the motor to the brush appears to be worn and I need to source a new belt. Not sure if the gears on the motor are also worn out but it is likely. Wondered how you found out about the part number. Mine is the Bosch rebadge of the original VAX model.
Would appreciate it if you could share any of the information you have or receive from the forums. Also, do you have a part list or a repair manual? Is this avaiable on the net? Look forward to hearing from you.
Cheers
Subbarayudu
sdarisi@juno.com
I ordered both a motor and belt by calling the Bosch service number in the manual and installed them myself, but quickly they failed again, the nylon cogs burned off (wish I could just get the cog wheel, but they have to sell you the whole motor). I bought a second Vax branded machine, which worked okay at first but now it constantly needs to be emptied for suction. Now I'm hoping to swap the bottom of my new machine with the top of my Bosch which doesn't have the suction problem. Good luck. Susan
Posted on Jan 17, 2009
How do I replace a broken belt on vacuum cleaner - Hoover Modell U5465-900?
The Brush is pressed into a small holder on each side of the vacuum case. You must pull the brush forward (out) from the holders and on the brushes side is a spindle where the rubber belt wraps around. Remove the old belt, clean off all debris and put the one end of the new belt on the spindle end of the vacuum motor and the other on the brush end. Push brush roller back in place and you are good to go.
Feb 08, 2018 | Hoover Vacuums
Why doesn't the brush roller revolve?
Remove the end caps and inspect for hair or other material. Remove whatever you find.
Aug 16, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
The roller brush will not turn. The belt is not
Sometimes the belt can stretch cause the roller to not turn. Also make sure the roller brush is free of any debris.
Use this link to access your vacuum to change belt or clean the roller brush.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 27, 2010 | Hoover U5068-900 Sprint Upright Vacuum
How to replace belt on Hoover U6626-900 Wind Tunnel bagless.
Click this to go to a site that will show you (complete with illustrations) how to change belt.
I hope this helps.
Jan 19, 2010 | Hoover U6630-900 WindTunnel Bagless...
Which direction should the brush roller rotate?
take back to repair shop that is most likely the case thank you for useing fixya please rate me
Feb 24, 2009 | Vacuums
The brushes aren't spinning
The brushes are belt drive by a belt. The belt is probably broken. You can purchase a new belt at a local discount store and replace it. You won't find anything that looks like a pulley, it'll just be a bare round metal portion of the brush assembly that is located at one end. The motor end will look similar.
Feb 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes do not turn
You should see if the brush belt is broken. I broke mine you can find the part at walmart or on bissell.com
Sep 02, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bosch vacuum
check the belt, it might be stretched or broken
or carpet fibers and hairs may have clogged up the brushes to keep them from rotating
let me know if this isn't the problem
Mar 22, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
388 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
