Question about Denon AVR-1100 Receiver
Fuse i think i blew a fuse where is the fuse boxon a denon avr 1100?
  • 624 Answers
Unplug the receiver first, then take off the top and follow the A/C cord into the unit. It should go right to the fuse, or it will go to the transformer and then the fuse. It should be a glass fuse for this unit, about an inch or so long and in a cylinder shape with metal tabs on each end. You can usually tell if it is good just by looking at it. If the glass area looks a little black it is bad, if it is clear you need to look very close and see if the filament inside is intact and not broken or separated at any point. A clear fuse can still be bad, that's why you need to look close. If the filament is in good shape, it is probable good.
If you replace the fuse and then plug it back in and turn it on, and then it blows the fuse again, please do not keep trying to turn it on or put in a higher rated fuse. It will only damage the unit further. You will need to have it checked by a service technician, it probably has a blown channel and replacing the fuse over and over again will only damage more parts.
Posted on Nov 09, 2008
Where is the fuse in a denon AVR-887
It has to have one---follow the power cord inside the unit--if fuse is good consider taking it to a shop for an estimate.
Jun 17, 2012 | Denon AVR-887
How do i reset AVR-1100
On the rear panel of the AVR-1100, there is a hexagonal point of contact which is called "Circuit Breaker". On the "Circuit Breaker", you can find the Reset button. Press and hold the Reset button to reset the device.
Ensure that all the excessive loads to the AVR-1100 are disconnected prior to resetting it.
May 28, 2012 | Denon AVR-1100 Receiver
Heard a "pop" and my
Maybe. Clearly something blew up. Diagnostic time costs money. Then there are parts and labor.
You can get a new one on ebay ending tomorrow for as little as $140 delivered.
Apr 25, 2011 | Denon AVR-2105 Receiver
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Control other devices connected to Denon AVR-1100
No you can't use this remote to control other devices unless they are Denon devices. This is not a learning remote
Jan 24, 2009 | Denon AVR-1100 Receiver
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
Manul denon avr-1601 en castellano
Espagnol as well ...I think
Dec 12, 2008 | Denon AVR-1601 Receiver
No display; No power
Your unit has a hard short in it. This is usually a power supply problem. Most likely the rectifier has failed. This should be a relatively simple and inexpensive repair. Figure on $10 for parts plus the local labor rate.
Jul 16, 2008 | Denon AVR-1804 Receiver
Denon Avr-1803- multiple room audio difficulties!
it is true pre amp check your cables and confirm in (avr-1100)that you select the right input.
May 27, 2008 | Denon AVR-1803 Receiver
What failed component causes protection error message to display right at power up.
well, i just got this thing from a friend. its a Denon AVR-800. when powered up it displays the stops, just before finishing a -protect- shows up. There's a little red light standby light that blinks off and on also. i think that has to do with the internal problem. any suggestions?
Apr 03, 2008 | Audio Players & Recorders
Denon AVR-1100 Receiver Logo
234 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
