Question about Dayton G73 Utility Heater
Dayton G73 heater
I was thinking about using this in my basement, instead of hardwiring could I get a cord and plug it in my dryer receptacle, when dryer is not in use?
    Genius:
  • Dayton Master
  • 2,047 Answers
Should be adle to if the voltage is right
Posted on Jan 04, 2009
Dayton g73 electric heater less than two months old and thermostat goes out any ideas
I WOULD TRY TO BYPASS THE THERMOSTAT TO MAKE SURE THE UNIT WORKS AND REPLACE THE THERMOSTAT IF IT DOES , SEE IF IT IS UNDER WARRENTY, MY GUESS WOULD BE THAT IT IS JUST DEFFECTIVE, AND YOU ARE TRYING TO FIND A CAUSE, THIER IS NO REAL CAUSE THAT I CAN THINK OF THAT WOULD BURN UP THE THERMOSTAT IF IT WAS OR HAS BEEN WORKING, GOOD LUCK
Jan 26, 2010 | Dayton G73 Utility Heater
Dayton G73 Utility Heater will not shut off until it reaches the high limit
Its probably trying to tell you something is wrong with me.. find the root cause!(like the fan motor is stopping and then the heat builds up and tripps the high limit switch!
Dec 22, 2009 | Dayton G73 Utility Heater
Need ignitor and gas valve for heater
They sell dayton stuff at Graingers
Dec 04, 2009 | Dayton G73 Utility Heater
I have installed a Dayton G73 heater in my garage along with a 240V outlet. I am using a 3 prong dryer cord and I am having difficulty figuring out which wire to hook to L1 and L2. I have determined the...
here's a link to the install guide
www.air-n-water.com/manuals/G73.pdf
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Installation-Dayton-G73-Garage.htm
Nov 02, 2009 | Heating & Cooling
Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Dayton G73 electric heater
I just got my G73.  It comes with a new note that says "below 50 degrees the fan will cycle randomly (and might seem like its not working correctly) but once it is above 50 it will cycle normally."  it uses that to let the element re-heat quickly to bring the room up to temp faster.
Feb 13, 2008 | Dayton G73 Utility Heater
If that is a 240V unit then you are correct wiring L1 and L2 to black and red. Unless the unit uses 120V for something like a control panel, it doesn't need the neutral.
Jan 14, 2008 | Dayton G73 Utility Heater
Dayton G73 Utility Heater Logo
162 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
