Question about Refrigerators
Problem with freezer on older GE Profile Performance side by side
The freezer on my side-by-side GE just started turning off randomly. If I slide the temperature all the way to the left (warmest), wait a few minutes, then slide it back to the right (colder), something clicks and the light in the fridge dims slightly and the freezer is fine for a while. Somewhere between 12 and 36 hours later, I see water dripping out of the freezer and I have to do it again.
The model number listed inside is TFS28PBBG BS. When I looked it up on GE's site they translated it to TFS28PBBBS. This is the big stainless steel model with the beverage center in the refrigerator door. I think I bought it in 2000 or 2001.
fridgetech
  • 473 Answers
SOURCE: LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened.  Look for this first and let me know if there are no set screws.  If this is your setup then I would appreciate a solved rating.
Posted on Oct 18, 2007
erpaalai
  • 999 Answers
SOURCE: Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Posted on Jun 29, 2009
  • 102 Answers
SOURCE: Sub Zero 642 side by side stainless steel leaks water from right
remove the crisper drawers and you will see a drain trough and a drain line . One or both is most likely blocked. If you pull the drain line off the trough usually you can clear it with a turkey baster filled with hot water
Posted on Aug 05, 2009
Testimonial: "Problem solved, thank you!"
DeBruce
  • 145 Answers
SOURCE: stain (drip mark) on front of fridge???
We Use Debruce Polish in all our kitchens, especially cooktops and stainless steel. Debruce also works on polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff is perfect!
Posted on Aug 24, 2009
aasc
  • 1606 Answers
SOURCE: Lime Away dripped down my stainless steel
Get a bottle of mineral oil and coat the front of the refrig . Then wipe off , after a few minutes . This will allow the oil to get back into the pours of the stainless steel . You may even want to let sit overnight . By adding mineral oil to the surface ( even permanently ) this will keep fingerprints and other solutions , such as lime away , drinks , food , etc , of the doors , with gentle wiping .
Posted on Oct 25, 2009
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
GE Profile Performance: Fridge rose in temp to the point where milk is spoiling. Now Freezer is going up in temp as well. Ice is melting and food is no longer frozen. Ice forming on the back wall of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | GE Profile Performance 25.2 cu. ft....
My daughter's GE Profile performance TPS24PPBGRS side by side is accumulating ice at the bottom of the freezer. Can you help us with this problem? Everything else seems fine. Thank you
I had the same problem. Check the hose that feeds water to the freezer. Mine had cracked and was leaking to the bottom and freezing. good luck
Aug 27, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile performance double oven. getting an F7
F7 is a stuck keypad/button.
Push all buttons at random several times each. This will sometimes un-stick a stuck button.
If that does not work the keypad control will have to be replaced.
Jan 16, 2010 | GE Ovens
GE side by side Profile Performance.. water freezes on the floor
hmmm could be a really bad defrost problem but we will most likely find that the drain is plugged..... i recommend taking the food out and turning the machine off overnight if you can
May 06, 2009 | GE Profile Performance 25.2 cu. ft....
Refrigerator/FREEZER
The problem was solve but not by turning upside down.
Jul 19, 2008 | GE Refrigerators
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
