I tried to innitialize some diy changes to my pc to improve the speed and performance, but now i cannot use a lot of the programs and i cant connect to the internet. But i have also forgotten my bios password so i cant get in there to try to set things back to the original factory specifications.
You will have to remove the power cord, remove the batteryand remove the CMOS Battery that is located on the motherboard. On mostcomputers you will have to take the laptop apart to get to the cmosbattery. On some systems it looks like a silver nickel that you will needa small flat head screw driver to pop it out. On other systems it will beinside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put itback in and put the laptop back together. Boot the machine and you'llprobably have to go into the Bios or System Setup because the system will haveforgotten the date, time and password.
SOURCE: want to restore compaq presario to factory settings
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
this doc may help u ...
SOURCE: forgot bios password
1. Shut down the computer. If you are unsure whether the
computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery pack by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch 1 to the left. (The
front edge of the battery pack disengages from the
computer.)
c. Lift the front edge of the battery pack 2 and swing it
back.
d. Remove the battery pack.
5. Remove the RTC battery from the socket on the system
board.
6. Wait approximately 5 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any
battery packs at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
SOURCE: acer aspire 3690 bios reset
Underneath the ram (remove ram) is a jumper marked J3
short this out for a couple of seconds.
This will reset bios right back.
Boot and go straight to bios (F2) and set your options as needed there.
Eg date, time, drives,and any other options the bios needs to be able to boot the machine. When you have done make sure you SAVE then exit which will re-boot.
If you didnt mess any bios settings you should be back in business
Is this information was useful please click
SOURCE: crack bios password on compaq nc6320 - please
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
