Question about Frigidaire 24 in. GLD2150RCC Built-in Dishwasher
Dishwasher problem solver
The glasses feel dirty like a film on them from the dishwasher?
2 Suggested Answers
  • 6 Answers
SOURCE: Glasses have a film when dishwasher is done.
There are several things that could cause this; 1. The rinse agent dispenser is out of rinse agent(Jet Dry). 2. The dispenser is not working and is easy to replace by removing the four screws that hold the door panel on and the two that removes the dispenser(be sure the breaker is turned-off). 3. The water temperature coming into the unit from the water-heater is not hot enough. 4.Your water may need to be tested for excessive minerals or chemicals. 5. Low grade detergent may not dissolve correctly.
Posted on Aug 06, 2010
Dishes are often dirty and glasses are cloudy even though they are rinsed before they go into the dishwasher
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Apr 02, 2011 | Whirlpool Dishwashers
After 4 years the glasses are suddenly coming out dirty with original grease marks and fingerprints on just some
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | Asko Dishwashers
My Kenmore 16379 dishwasher is not cleaning well at all. We've tried powders, tablets, and gels with no better results. Glasses are dirty, dishes have soap residue.
heatman101
Jan 26, 2011 | Kenmore 16372 / 16374 / 16379 Built-in...
My Jenn- Air dishwasher (2 years old) used to clean great but now it is leaving a white film on the dishes and there is often residue left in the glasses as if it is rinsing with the dirty water. I can't...
heatman101
Nov 20, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
There is a film on all the dishes and glasses. They look dirty when the wash is finished. You can feel the film.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Other things to try: CLR on the spray nozzles to loosen up cloggs.Check the filters to be sure they are clear.
Jul 14, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My electrolux icon dishwasher leaves food residue in the interior of glassware and mugs. It has etched and left milky scratching permanent texture to all glassware. I have replaced glassware change...
heatman101
Mar 10, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Dirty cutlery, glass wear getting a dull film
WHAT IS THE TEMPERATURE OF YOUR WATER, SHOULD BE AROUND 140 DEGREES.
Feb 26, 2010 | Dishwashers
Dishes are no longer cleaned properly. They have a white milky film BUT if hard water is the problem, why were they coming out perfect for the past 8 years?
If the film is only on glass. wash the glass with a citrus cleaner, if they get clean then your glass ware may have been etched by your had water and the detergent from your dishwasher is staying in the etched glass.
If this is not the case, then your dishwasher might not be getting the proper volume of water, witch will decrease the pressure of the wash arm or your spray arm might be dirty.
Jan 08, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Miele dishwasher cleans most items, leaves pans dirty
water may not be hot enough...check thermostat in waterheater.
Mar 13, 2009 | Dishwashers
Dishwasher
Go to www.dishwasherfilter.com and have sparkling clean dishes with no film or spots, every time!!!
Make sure you use promo code DF5150 to get an additional discount!
Nov 14, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Frigidaire 24 in. GLD2150RCC Built-in Dishwasher Logo
64 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
